Knickers in a twist with TMP and Vistitle install
  • Knickers in a twist with TMP and Vistitle install
    I'm just loading up a new little laptop as a mobile, albeit pretty crippled, alternative to the Edius station at home.
    It's Win7(home edition) and I loaded and tested Edius 5.12. Then loaded VisTitle which I only tested standalone. I then remembered that I have potential reedit jobs that would need TitleMotion so loaded that.
    First, Vistle no plugin found in Edius and now doesn't run standalone either saying it can't find a couple of files so have uninstalled and plan to reinstall after testing TMP.
    TMP doesn't open in Edius and on trying to reinstall refuses saying it's already there.
    So... how do I uninstall TMP to either try a reinstall or just get rid of it, and what's happened to Vistitle?
    Being new to Win7 I'm out on a limb here.
    Cheers Alan
    Alan.
    have you set TM Pro as the default titler in application settings?
    many programs don't install correctly with windows defender enabled, you may also disable UAC
    Windows 7 64bit optimization settings for Grass Valley Edius users by disabling services and windows features that may otherwise slow the workflow
      Thanks Anton
      No, just clip\new\titlemotion
      I found the uninstall option for TMP under Edius uninstall so have stripped out everything now and plan to reinstall Edius & all plugins from fresh.
      My guess is that the laptop video card specs don't meet requirements.
      I'm used to it all running very smoothly loading from an SSD drive on the other station so perhaps I'm being impatient?
      Cheers Alan
      Alan.
