P Pro CS5 can't read /edius HQ clips
  • P Pro CS5 can't read /edius HQ clips
    Just tired to load an Edius 5.5 HQ clip in Premiere Pro CS5. Sound with no video is what I get. And the same with AE CS5.
    Apparently the Adobe products will not recognize the Edius HQ codec.
    Both E 5.5 and CS5 are on the same machine. Can this be fixed?
    This is known and they are looking at it right now :)
      They??Are they the same as them:) or Everybody?
      Randy
        just curious:
        the OS is...?
        Paranova Films
        Cali - Colombia
        http://www.paranovafilms.com/
          Originally posted by Paranova Films
          just curious:
          the OS is...?
          I would imagine the OS is irrelevant. I am led to believe that it is because both AECS5 and PProCS5 are 64bit ONLY: therefore all codecs and third-party plugins must also be 64bit apparently. Some thrid-party plugins have been released as 64bit versions to work with CS5, e.g. some but not all Boris FX and MB Looks for instance.
          I hope if "they" are looking at the Canopus HQ codec "they" might look at a Mac OSX decoder/player to make it cross platform.
          That "they" are looking at it is good news though.
          BTW, where does that leave h.264 and mpeg2 out of interest? Do they import?
          Mac Pro (mid-2010) 2.8GHz quad Xeon, Ati 5770 graphics card, 12gb ram 4 x 1TB HDD plus external eSata
          MacBook Pro Retina (2014) 2.3GHz Nvidia 650M, 512 SSD, 16GB Ram external HDD on USB3 and thunderbolt.
            The codecs don't have to be 64-bit, Adobe simply chose not to support 32-bit codecs. From a technical perspective, there's no reason why they couldn't have make it work.
              I hope someone fixes it, it would help me quite a bit. I am not holding my breath though.
              Randy
                Yes, the OS would have to be 64 bit because CS5 only supports 64 bits.
                From Adobe's FAQ:
                Does Adobe Premiere Pro still support 32-bit operating systems?
                Virtually all Intel® based Mac computers support 64 bit. Adobe Premiere Pro does not support 32-bit Windows systems with CS5 because offering only 64-bit support enables Adobe to optimize performance significantly and take full advantage of the performance benefits of 64-bit support.
                If you are using a 32-bit version of Windows and purchased a Windows copy of CS5 Master Collection or CS5 Production Premium, Adobe has included a complimentary copy of Adobe Premiere Pro CS4 for you to use until you upgrade to a 64-bit version of Windows Vista® or Windows 7.
                If you are using a 32-bit operating system and purchased a standalone version of Adobe Premiere Pro CS5, you will have to upgrade your operating system to a 64-bit version of the Mac OS or Windows Vista/Windows 7.
                Jeff Chandler
                High School Broadcast Adviser
                Freelance videographer & editor
                  Sorry, I meant irrelevant whether it was Vista 64 or Windows 7 64 in their various flavours.
                    Export to uncompressed. That should work.
                      CS5 under OS X still supports 32bit QuickTime codecs...because Adobe runs a 32bit handler in the background to access 32bit codecs.
                      Too bad the Windows version doesn't have this.
                        Originally posted by STORMDAVE
                        CS5 under OS X still supports 32bit QuickTime codecs...because Adobe runs a 32bit handler in the background to access 32bit codecs. Too bad the Windows version doesn't have this.
                        Interesting development in the War of the "A" Corporations.
                          RE Quicktime this does work under windows as well as Mac os. Obviously Adobe had to write support for Quicktime since so many people use it. Its really just non-64 bit codec AVI files it does not work with, and of the ones I have tried Canopus is the only one that is not right now.
                          It works with uncompressed, variations of MPEG and H264, P2 etc.. I tried Canopus lossless and that did not work either.
                            Cineform Neo Scene is supported and has 64bit support for their codec - for those needing a solution, it's the only one that is supported right now - used it in Vegas Pro 9 64bit before moving to Edius Neo 2. Brought my clips into Neo 2 and they were seen without issue. I know it's not a native Edius solution, but it does bridge the gap so speak.
                            I'm hoping the people at Grass Valley are working on their own 64bit announcement with Edius 6 - along with10 bit color space and full support of AE Plugin support would be killer IMO - just sayin.
                            Cliff Etzel
                            Micro Documentary Filmmaker
                            bluprojekt | SoloVJ (blog)
                            Desktop: OS: Win7 Pro x64 | CPU: Intel Q9400 | Mobo: Intel DG33TL | 8GB G.Skill Dual Channel RAM | Boot/Apps: Seagate 160GB 7200RPM | Audio: Seagate 160GB 7200RPM | Source: WD Black 2x750GB Raid 0 (1.5TB) | Graphics: nVidia GT-220 1GB DDR
                            Laptop: Dell Latitude D620 | C2D 2.0Ghz | 4GB G.Skill RAM | OS: Vista x64 | Primary HD: WD 320GB 7200RPM | Video HD: WD 250GB 5400RPM
                              any news on the hq codec with cs5? i really hope there will be a solution soon!
                              thomas
