virtual dub
  • virtual dub
    downconverted some hd from ex1 in VD. video looked great but on some movement there would be a slight strobe/motion blur. any idea why?
    Try reversing field order
      Hey Jim before you add your clip to the time line right click on it in the bin and under properties change the field order to upper.
      Take care
      Ronnie
      www.ramtv.tv
      Ronnie Martin
      Kato Video Productions
        Virtual Dub is one of the greatest pieces of software I've ever used. For downconverting it's amazing (props to Anton once again). There is so much more it can do.
        David
        DMS Films, New York
        Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.com
          Having just discovered it I second that!
          Alan
          Alan.
            Great for rotatiing the frame a little when your horizon is off a bit as well...Lifesaver.
