ProDAD Vitascene and edius 5.5 - crash
    Originally posted by jasonsilzle
    Hey guys I deliberately turned my Windows 7 (32B) video settings to windows basic and all the EDIUS VISTASCENE crashing stopped. Give it a try. Currently running Edius 5.51 and Vista scene 1.0.46
    This is obviously not a solution, as we own Win 7. ProDAD's support could fix the issue itself.
    Workstation: Dell Precision T5500 | Edius NX HD Suite w/ Bay | OS: Win7 Ultimate x64 | CPU: Two Intel Xeon X5550 2.66GHz | 48GB 1133MHz DDR3 ECC-UDIMM | Boot/Apps Drive: WD5002ABYS 7200RPM | Video: 2x500GB Raid 0 (1.0TB) | Graphics Card: NVIDIA® Quadro® FX 3800 | UAD-1 | TC Electronic PowerCore Express
      As a temp fix, go into you edius directory and right click on t he edius.exe - Properties - Compatibilty Tab - select "Disable Visual Themes" and Disable Desktop composition".
      This should pretty much turn your machine into the basic theme etc while edius is running and should revert once it is closed.
        Everyone knows this, we have all been waiting for an update to fix this problem with Vitascene, and also with Heroglyph as well,
