BluffTitler iTV vs Vis Titler
  • BluffTitler iTV vs Vis Titler
    Anyone knows the differences between the a/m two titlers ???
    Which one is better in 3D titles composting ??
    Dual Xeon E5520, Supermicro X8DA6, 24GB DDR3, WD VelociRaptor 300GB, 6x 1TB WD Carvier Black (Raid 0), ATI 5770 gfx, EMU 1820, Seasonic 750w PSU, Canopus NX (PCI-X), Windows 7 Professional 64, Edius 5.12
    I don't have Bluff Titler, but I will say that VisTitle is the best titler I have seen in about 10 years. Like a mini After Effects for Titlers.
      BluffTitler is a good product for 3D title compositing, and it have real 3D text, have particles,plasma layer and other good features.
      But I think it is only suitalbe for some short 3D text effect, my means is that if you just do little title work, and want have excellent 3D effect, you can try BluffTitler. Remember, it maybe cannot create a "Rectangle" object.
      In addition, in my memory, it have not a plugin for EDIUS, it is a standalone program, you will have to render and export image sequence files to disk files, and then import these files to edius, and if you want to modify, do those jobs again.
      VisTitle is designed for EDIUS, and intergrated with EDIUS, it can do a lots of title jobs which is not avaliable in BluffTitler.
      Any way, I think that VisTitle and BluffTitler is not same product, maybe we should not compare them. :)
        I have both. I do prefer Vistitle over Bluff Titler.
          Personally I have never been impressed with the quality of the renders from bluftitler.
            awww...what an insights from you guy's inputs.
            Yes, blufftitler & Vis Tilte are of different class no doubt.
            Under corporate video production sense, bluff title may seems easier to create but for Vis Title, there are more tweaks available than the earlier said. I had also read feedback from bluff titler users about its 'resolutions' issue.
            The main push factor of Bluff titler for me is a non-Edius plugins. That essentially affects the work flows during my post-production works. If given a choice, I may still consider Vis Tile despite it higher pricing. Its definitely a much versatile titler to be bundled with Edius thus far IMO.
            Btw, any cue for me to get a Vis Tile in Singapore ??? Is the price still USD$599 now ???
            Thanks in advance guys!
              Don't forget that they are 2 very different products. Maybe yo should investigate a bit more to see which one would serve you best. :)
                I think the VisTitle price here in the US is $379.
                  For me personally, the closest program to Vistitle is the titler in After Effects.
                  That is what I was using, for the most part, for my titles. Vistitle is at 1.1 and working on 1.2 now. For a new program, issues are being addressed quickly and promptly.
                  It is a very good titler that can do more than you will probably use.
                    Any idea on UK price yet
                    Normally 1$=1£+17.5%Duty which makes it expensive
                      Wow... price at USD$379. I hope its still holds a promo price at USG$299 as prior at its recent NAB exhibitiion.
                      Yeah. I guessed Vis title would be more suitable for me compared to Bluff Titler.
                      Im wondering if Vis Title would be participating in the coming Communic & Broadcast Asia in Singapore next month which i can get a copy of it from them locally??
                      Thanks guys. Have a feelings that Vis Title may be bundled with our next generation of Edius 6. Haha..If that happens, would be a great blessings to us all!
                      Cheers.
                        Personally havent used Blufftitler, but i have Vistitle and it is awesome, apart from the odd crashes which 1.2 will hopefully resolve. Who knows as Sync says maybe it will be bundled in with Edius 6....
                        1. HD Storm+expansion bay,i7 1st: HD Storm+expansion bay,i7 920, Asus P6T,6Gb Corsair RAM,Ati HD4670 512MB,Lian Li PC-A7110B Tower Case,NEC 24" Monitor,Win 7, Edius Pro v6.06,Firecoder Blu card
                        2nd: DV-Storm2,HD-Spark,Q6600 2.4Ghz,Asus P5Q Pro, 4Gb RAM, Ati HD4670 512MB,Antec Sonata Quiet case, NEC 20.5" Monitor,Win 7,Edius Pro v6.06
                        3rd: i7 920,Asus P6T,6Gb Corsair RAM,Ati HD4870 1GB, Antec Solution series quiet case,NEC 20.5" Monitor, Win7,Edius Pro v6.06
                        Gigabit Ethernet
                          DVC has Vistitle listed
                          " VisTitler for EDIUS £250 +VAT
                          VisTitler is a new titling program for EDIUS that can do animated 2D and 3D titles and a lot more besides. It is extremely powerful and if you want more options then offered by EDIUS' built-in QuickTitler then Vistitler is the best option. "
                          Can't find a buy now button though, but its a sign we are getting UK dealers :)
                          Software:
                          Edius 8.5 Workgroup
                          NewBlue FX
                          Hitfilm Ignite
                          Vitascene 2
                          Newblue TitleMotion Pro
                          Smartsound 5.8
                          Desktop:
                          MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
                          Laptop:
                          MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
                          Cameras:
                          Panasonic HC-VX870 4K
                          GoPro Hero4 Black
                          Panasonic GX8 (Stills & Video)
                          Garmin Virb 360
                            VisTitle is officially Awesome!
                            As a longtime EDIUS user and a longtime After Effects user, I can tell you that VisTitler is the best thing to come along for EDIUS users in a long time.
                            While not completely "perfect" - it is way better than Inscriber TitleMotion and much more sophisticated than the easy-to-use QuickTitler.
                            VisTitle brings extremely powerful toolset for advanced users that understand concepts like keyframing and bezier splines, etc.
                            For novices, there are simple tools for quickly applying particle animations and character-by-character animation moves to a word or multiple lines of text. Thankfully these templates make quick work of flying in a line or phrase letter-by-letter.
                            Be fore-warned however that, like Adobe After Effects and Photoshop, it will take you some time to learn the concepts and feature-set. This is a very deep program and there it is obvious that a LOT of thought that has gone into designing the software UI and Toolsets.
                            Like Inscriber TitleMotion, VisTitle also includes tons of well crafted presets for font styles, lower thirds and drawing objects/primitives.
                            My overall rating for VisTitle 1.5 is 8.5 on scale of 1-10.
