Work flow with Moviefactory
  • Work flow with Moviefactory
    Can someone give me a good workflow from Edius to burn a DVD with Moviefactory?
    For example if I have a SD PAL 16:9 timeline project in Edius, what do I do next?
    Print to an MPeg2 file 8mb =1hour approx
    and then bring into MF
    how long is the timeline ?
      Thank you for your help.
      I have not started anything yet with Edius. I just wanted to know how to use a project and get it into DVD MovieFactory.
      I didn't know if I had to make an mp2 file first in Edius or if Moviefactory did the conversion.
        If you have edited the timeline you might as well do it in Edius otherwise you would still need to create another avi from timeline to import into MF which would then convert so you save a lot of time
