Imginate 2
  • Imginate 2
    Is it Vista 64 friendly?
    Alan
    Alan.
    not sure
    works fine in Win7 64
      Alan
      Yep it works fine in Vista 64bit, and as Anton says windows 7 64bit.
        Thanks Guys,
        Is it a quicker easier way for handling stills stuff inside Edius than having to round trip to AE
        Alan
        Alan.
          Much quicker. Thee is an update to Imaginate 2 in the registered users setion
            I'd have to buy it. But I've also seen good reviews of a package called DigiRostrum. Okay it's not an Edius plugin but has very impressive reviews and is half the price.
            Alan
            Alan.
              Alan
              and you will need to render
              whereas, with IM2 you render nothing, you simply save the project, takes 1 sec and then open the project in the Edius bin and stretch it to any length on the timeline and causes 0 quality loss compared to other solutions
                Is there a demo version of Imaginate 2.0 anywhere? I've looked but can't find. Before I bought Edius I downloaded the demo... I liked... I bought...Simples!!!
                Can the same be done with Imaginate?
                Mark
                Main Editing System: Sinclair ZX81 0.75Mhz chip (Overclocked to 12Ghz), Liquid Nitrogen Cooled. 48k of RAM, Compact Cassette tape drive (9600 baud), 4" B&W monitor. No keyboard - all input by thought transfer from a colander on my head. Gives me 180 layers of 4k in real time (all with 3D PIP added) and can encode and burn a 2 hour Blu Ray in just under 12 seconds. Custom editing chair that floats on magnets 2 feet above the floor. I am also able to travel in time.
                  I don't think so as it is a discontinued product now.
                    Thanks for the advice Anton. I'll go with Imaginate 2 for the reasons you propose.
                    From my restricted trials of the Digirostrum sw it looks like it has issues with HD and 64bit versions of windows.
                    Alan
                    Alan.
                      Shame! It looks like there's no trial version of Imaginate 2 to try.
                      I've come across a retailer in the uk that advertises that the Imaginate 2 upgrade is either for Imaginate 1 upgrade or intall for Edius users. Has anyone come across this?
                      Alan
                      Alan.
                        Try DVC; they appear to offer it for £129 ex VAT.
                        See here:
                        http://www.dvc.uk.com/acatalog/Effects_programs.html
                        DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
                          Arrrgh! DVC imply that it's not fully Edius 5 friendly.
                          Any problems with Imaginate and E5.1 anyone?
                          Alan
                          Alan.
                            I don't understand that one. Edius works fine with Imaginate. They were made to work together.
                              As long as the latest patch is installed, downloadable in the registred user section, I myself and lots of other users can vough that the IVP project file from imaginate 2.x works great and realtime in edius 5.12
                              Rendering out a avi file is not the correct way to go here.
                              There is 1 small problem, if you want to call it a problem, and that is that you have to manually change the lenght of the project on the Edius timeline to match the lenght created in Imaginate, not sure why, but that's the way if is.
                              Fast to make a project, resulting in great end quality.
