In title motion pro I used to have templates of different lower captions . They are no longer there I am sure it is me but have I missed enabling something?
titlemotion pro
nothing in the dropdown at top?
what about file menu, template manager? is that empty also?Anton Strauss
No nothing in either place. I used to get a long list with all the different caption supers. I am trying to re load TMP pro but it gets to the end and does not finish. That may be a local problem on my machine. I thought at first I was using the wrong second disc (you need the TMP form the earluer version as you will know) but that does not seem to have any effect. I am still trying.E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
Problem solved but still unexplained why. Due to hard disc changes I reinstalled Edius 5. It now resides on the main SS disk. The previous installation I remembered is still there on the previous main drive disk. Drilling down into the TMP folder lo and behold all the files were there. By using the Manager in TMP I was able to copy them over to the present folder and they are all now there. Quite why I do not know should I have delelted them first before reinstalling? maybe. The good thing it has introduced me to the File manafer in TMP which I had never looked at before.
Further help now I there . If I apply an animated caption it only last 60 frames or so how do I change the length? I can varty it under FX but not under animation it would seem.Last edited by vortigern; 02-27-2010, 02:24 PM.E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
there should be a little timeline inside TmPro where you can type various times including overall duration
be sure to stretch it out on the Edius timeline to reflect the new durationAnton Strauss
