Released EdiusPLAY 1.0
  • Released EdiusPLAY 1.0
    Has been released for version 1.0 of the plug-in EdiusPLAY.
    Collecting numerous reports from users, we realized this utility
    Edius allows you to listen to it before you import it into the bin, an audio track.
    This allows you to quickly choose simply the song you want to use.
    It is really simple: just open the import file, select the audio track and press F11, it will start playing the song. Stopping to press the F12 key.
    The utility is free and can be downloaded from the site www.galaxisas.it
    Giovanni Abate
    Galaxi s.a.s.
    Italy
    Error
    Error on installation ... it says
    "Impossible creare la sequente cartella: TRUE"
    what is this???
    www.anima3dproductions.blogspot.com
      The error may be due to the version of EDIUS installed.
      EdiusPLAY works with Edius 5.x
      Giovanni Abate
      Galaxi s.a.s.
      Italy
        I have 5.12 on 4 machines... i get the same error
