Stumped using VirtualDub encoding to Canopus HQ
  • Stumped using VirtualDub encoding to Canopus HQ
    I've been trying to use the latest version of vDub 1.9.8 to batch resize clips using the Canopus HQ Fine setting. Can't seem to get it to work - vDub sees the codec, but it refuses to show video or play audio of any clips encoded in Canopus HQ codec.
    I have no problems getting Cineform Neo Scene clips to work with it so it's got to be something specific with the Canopus Codec - and all versions of Canopus codecs show up in vDub.
    All I get is black video frames.
    Any ideas why???
    Cliff Etzel
    Micro Documentary Filmmaker
    bluprojekt | SoloVJ (blog)
    Desktop: OS: Win7 Pro x64 | CPU: Intel Q9400 | Mobo: Intel DG33TL | 8GB G.Skill Dual Channel RAM | Boot/Apps: Seagate 160GB 7200RPM | Audio: Seagate 160GB 7200RPM | Source: WD Black 2x750GB Raid 0 (1.5TB) | Graphics: nVidia GT-220 1GB DDR
    Laptop: Dell Latitude D620 | C2D 2.0Ghz | 4GB G.Skill RAM | OS: Vista x64 | Primary HD: WD 320GB 7200RPM | Video HD: WD 250GB 5400RPM
    are you resizing to a legal Canopus HQ size? only legal broadcast sizes are possible
      Resizing to 1280x720p from 1440x1080i and applying deinterlacing in the process of the queue
      Cliff Etzel
        why are you using virtual dub for that?
        simply start a 1280x720p project in Edius and load the 1440x1080 file, set its field order to progressive, it will play fine with no artefacts
        it could be that Neo does not have a 1280x720 preset? Edius5 does
          Really? I was under the impression I would take a performance hit doing it that way...
          Cliff Etzel
            not at all
            Edius does great scaling of 1440 to 1280
            Vitual Dub is only required if going from 1440 to 720 for DVD
              not at all
              Thanks Anton - you just saved me a world of frustration :)
              btw - Neo 2 does have a 720p preset
              Cliff Etzel
                Andrew - All I'm getting is black/blank video rendering out from vDub per your instructions - any ideas why?
                Cliff Etzel
                  I have a licensed copy of Edius Neo 2 - could it be that not having full Edius 5 is the problem???
                  Cliff Etzel
