how i edit .x3d file
  • how i edit .x3d file
    CAN anyone tell me how i edit .x3d file
    i have many .x3d file but dont know how i edit.
    or
    please tell me how i create new .x3d file for xplode
    thanks
    Dear MK2007
    this is a "double posting" from you... 8-(((
    you have exact the same the same question written, in the existing (and correct) thread click for ==> Xplode Pro + files .x3d
      thanks
      You can't edit x3d objects, but you can create new ones:
      1. with NewTeks "LightWave 3D"
      using
      Xplode Lightwave 5.6 Compiler
      Filename: xplode_lightwave56_comp_10003.zip
      Released: 11/22/2005
      2. Convert any 3D Studio Max objects
      using
      3DS Compiler for Xplode
      Filename: Compiler20001.zip
      The tools are avalaible for registrated XPlode 4 user
      on GV download section
      Eric
      English is not my native language
      ___________________________________
      System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
      System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
        using
        Eric
        I Dont have Lightwave 5.6
        i have Lightwave 9.0 ur 9.5, but Xplode Lightwave 5.6 Compiler is not work with 9.xx version
          Compiler works perfect on my LightWave 9.3
          alternativ you can create 3D Object on any 3D Modeller witch has ann Exporter to 3ds format.
          Just use 3ds converter to get x3d files.
          its already posted here:
          http://ediusforum.grassvalley.com/fo...ead.php?t=5399
          Now I have testet "Lightwave 5.6 exporter for Xplode" with LightWave 3D 9.x:
          PlugIn works perfekt in 9.3. You can export objects and scenes (including movements)
          Eric
          why do you make double postings?
          Eric
            when i try to export x3d file from lightwave 9.3 i got error - Unable to get "LW Image List 2'!
            then it say
            Plug-in CanopusX3dExport failed to start
            what i do now
              what i do now
              first you shoud to pay more attention to previos postings:
              --> create 3D objects in LightWave --> export as 3ds --> convert to x3d
              Eric
                Dear Eric You have any video for training
                I mean how to create 3d bjects file in Lightwave 5.6
                  Its very easy to create .x3d files. I have tried 3dmax object files (.3ds). use cnopus Compiler to convert .3ds file to .x3d file.
                    can u pls provide me any sample video how to make x3d object
                    can u pls provide me any sample video how to make x3d object by lightwave and use it in xplode pro
