Check out VReal
  • Check out VReal
    Hi,
    Just thought I would share this with people, the Program is called VReal and uses NVidia Cuda Technologie, check it out at this link, it is a simple program with some great features. http://www.vreveal.com/
    Too bad it can't do hi def. Otherwise I'd love to try it out!
      It can do HD, but only up to certain res, they say that updates will improve this.
      swsw1550
      Senior Member
        Where's the EDIUS plugin?
        AMD Ryzen 9 5950X, AMD Radeon 6800XT, 64GB RAM, EDIUS X WG.
          Not so sadly. This is from their FAQ page-:
          "Does vReveal allow me to enhance HD video?
          No. You can import any video resolution, including HD, into vReveal and apply simple edits like rotate and trim. But you can only apply enhancements to videos with a vertical resolution of 576 pixels (PAL resolution) or less.
          Applying the computationally-intensive super-resolution enhancements to HD (720p and bigger) video would take an unreasonably long time on lower-end computer systems, leading to an unsatisfying user experience. So, this version of vReveal includes algorithms optimized for videos with less than HD quality.
          We are planning on releasing a higher-end version of vReveal in the future that would allow enhancement of HD video."
          Cheers,
          Stuart.
            We can only wish Mark.
              Yeah - I think we'd all like to know - where's the EDIUS plugin?
              Cheers,
              Alan
              Alan J. Levi
              Director
                No internet......
                Ordered the program, paid for it, to have it on hand. Then found out vReveal CANNOT be installed on any computer that doesn't have Internet connection. I NEVER go on the internet with my editor, for obvious reasons, and therefore tried to get a refund for the program I can't use. 7 hours of telephone calls, overseas support (which was impossible!), and emails finally lead to a credit. If you cannot connect - do not order!
                Cheers,
                Alan
                Alan J. Levi
                Director
