I need a sunset .avi file
  • I need a sunset .avi file
    Hi, I have just made a documentary about Kalapalo people in Mato Grosso. In my documentary is lacking in a good sunset. Is it possible to download it as .avi file? No matter the sunset is in Mato Grosso but every sunset is good for me. I will edit it with superimposition. If it is HDV or DV file is ok. I hope there is some web site where I can download it without paying. ;)
    thanks
    CPU: Intel i9 7940X
    SSD Drive:
    If you want quality, it is not free. Sorry, there is no free lunch here. Especially in HD.
      Hi, try vue 7...I have just bought it and is more than satisfied with the rendering results....they have an PLE version and one free version vue 7 pioneer...
      Regards
      A computer with a lot of stuff in it :)
        Hey tingsern, you are right but.... before I have sure that file adjust itself to new surroundings. I don't like to pay and to reject that file. This is my worry.
        thanks
        CPU: Intel i9 7940X
        SSD Drive:
          Regards
          Ludde, thanks for your suugestion.
          could you tell me if I have to study this software or it is so easy to use? I know the 3D softwares are a little bit haed to assimilate. ;)
          and .... where can I find the backgrounds for the software?
          thanks
          CPU: Intel i9 7940X
          SSD Drive:
            It´s really easy to get started with.....
            It is not a modeler, but more of a landscape 3d app....
            you place your objects in a sceen and render...
            here are some links
            e-on software makes VUE, PlantFactory & PlantCatalog: solutions for the creation of natural 3D environments for the VFX, CG, Gaming and ArchViz industries
            and check out the demo at youtube
            more..I did a sunset over water...took me 5 minutes to do it as a beginner...
            the results was more than I thought it should be
              here are some links
              Luddle,
              thanks a lot for your precious news. Could you tell me if it is a DV or HDV quality?
              CPU: Intel i9 7940X
              SSD Drive:
                Hi...I think the free version is only DV....with a vue 7 logo in the lower right corner...could esily be masked out ( don´t know if Could say that :))..I have bought modules so I have no problem doing it in HDV or HD....
                Regards
                  You might be able to grab a HD version off Vimeo or YouTube...but make sure to contact the author first before doing that.
                    I can send You a sunset.avi in FullHD if You still need one... From South Africa
                      Yes, I need it. I need some sunsets. Is a sunset over the sea or river?
                      How can I do the dowload, please?
                      thanks a lot.
                      CPU: Intel i9 7940X
                      SSD Drive:
                        Take a cam, go to the roof and shoot it.
                        At least the people can see that the documentary is a fake, not? :D
                        If you know matto grosso, then you can figure it that there's no sunsets over the sea, man.
                          Ha ha ha ... that's a good one :-).
                            I'm thinking you don't like traveling. Do you know brazilian rivers? They are as a sea. In Mato Grosso there is the Xingu river and it is big as Adriatic sea. Do you know it? I'm sorry if you don't lke traveling. I like it. ;)
                            CPU: Intel i9 7940X
                            SSD Drive:
