I need the morph plug-in to edius 4.6 whether so does exist? if not it is what simple way is it possible in order to do it into? I apologise for my trashy English (I am trying!)
morph
My dear polish friend!
your english is good, do not worry- we are all from different places with different cultures and I think this is great.
About morph plugin. I do not know any editing software wiith morphing abilities... You have to check composiying ones, such as Aftereffects, Combustion etc. There are also some simple and cheap morph utilities.
See, if you are buying a bicycle, you cannot expect that it will make you bortsh (hot soup) or play music... it is just a bicycle, right?Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
