Boris 9 on Edius 5
  • Boris 9 on Edius 5
    I wonder where you find boris effects in Edius 5 after you installed corectly
    the plugin?Not in transitions area,where?
    Can anybody help?
    Can anybody help?
    Its in the transistion root folder. Click on 'Transistions' and its there, aswell as the Filters folder.
    Boris 9.3 is best as it fixes the field order problem.
    Upon installation, select 'Edius 4', and then the installer will automatically install it into Edius 5 anyway, as Edius 5 is not listed.
    Raja Singh
    Sadha Video
    UK
    Gigabit Ethernet
      looks like this in filters, and similar in transitions
