Levelator vs. Normalize
  • Levelator vs. Normalize
    As always, I'm poking around with the new features in Edius and perhaps I'm not in the groove yet with Normalize.
    Below is a comparison of Levelator (A1) vs. Normalize @-6dB (A2).
    vows is a .wav export from A6 (really low audio and a monster spike at 12:15), then -6 dB Normalize added. Good, but not enough.
    vows.output is the Levelator output.
    Needless to say, for this use I went with Levelator.
    Any advice welcome for using Normalize.
    Levelator seems to apply a compressor/limiter then a normalize. Essentially this "squeezes out" the extreme highs and lows so the overall level can be increased further.
      So Normalize will peak at your set value? (not sure)
      I like the way the waveforms respond to the changes without recreating them.
      I'll play with mixed content to see how it works.
      Levelator does such a good job with spoken word, it's indispensable.
        As I understand it, the current Normalize will normalize the RMS (average) level to your set value. This means that if you're not careful, you can cause clipping.
        To be more specific on what I said earlier, Levelator seems to apply a compressor/limiter then a normalize to peak.
          Normalize appears to be non-destructive!
          A real plus IMO.
          The waveforms do not need to refresh. Cool.
