Title motion pro
  • Title motion pro
    I am trying to install Title motion pro.
    When thr greenbar gets to the last stop a message comes up saying 'Edius was not found - set up will not proceed'
    Edius is definitely installed as I have bee working with version 5 for two months. Why the meessage?
    It could be the wrong version to fit with Edius 5. Where did you get the TM?
      you must enter some registry entry
      or install the both programs in the same path [c:documents....]
      for detais pls reply
      [email protected]
        Title motion pro & EDIUS 5
        Reg History:
        HKEY_LOCAL_MACHINE\SOFTWARE\Canopus\EDIUS\Installa tion
        Name Type Data
        (Default) REG_SZ (value not set)
        DestDir REG_SZ c:\Program Files\Canopus\EDIUS 5
        DestFolder REG_SZ EDIUS 5
        PlugInDir REG_SZ c:\Program Files\Canopus\EDIUS 5\PlugIn
        VideoStandard REG_SZ PAL
        or Regfile : [email protected]
          Title Motion Pro & Edius 5
          I have EDIUS 5 ( A promo upgrade pack which including Edius 4 to allow use the upgrade, I only mnetion in case it has any bearing on my question ). The pack came with a Title Motion Pro upgrade disc ( small print can only use with previous versions ). I've now located a supplier of a full CD version of TMP but am concerned that because TMP seems not to exist on the web if there are conflicts with Edius, I'll be on my own ! Anyone advise if they really like TMP and why ? I've tried Graffiti 5.3 but hate the fussy timeline. Thanks.
            i installed title motion pro on edius 4, it is very good but i couldn't figure out how to make animation style title :=(
              Read the help file (manual). It will help
                Animated Tiltes Long Render Times
                Just wondering if there is a compatibility issue with Ttitle Motion Pro and Vista.
                Always before in Edius 4.6 when animating a title in TMP, the render time was fairly quick. Since going to Edius5 with Vista, the render is very long.
                Walk away for a long period of time long.
                Any suggestions to get the render times back to reasonable?
                Thank You
                Trisha Von Lanken
                All My Best,
                Mark Von Lanken
                Picture This Productions, Inc.
                www.VonWeddingFilms.com
                  Render the annimation in FX mode rendering will be at supersonic speed.
                  I have seen this slowness. :)
