Video Compositing
    thankss........
      Boris Red
      Our production house uses Boris RED 4.3 which has an acceptable interface as direct plugin to Edius. Once you understand what needs to be done for Boris to be used for compositing, it works quite smoothly. It's worth a try.
      Here is the homepage: www.borisfx.com
        Originally posted by Dry Biscuit View Post
        My daughter is a professional visual effects compositor and says there are only two main programs now in the. They are Shake (although not availiable in 64 bit versions) and the one that most production houses are going over to now is Nuke. The general opinion is that other products After Effects / Combustion etc are either dying or do not have a future in the film industry.
        Then she starts talking technical and loses me :))
        P.S. Dont shoot the messenger, this is what I have been told.
        The film industry uses Nuke and Shake for compositing, ie, adding new plates, removing wires, etc.
        After Effects is used for film openings, commercials, etc.
        There are plenty of companies who only rely on After Effects as their main application.
        Check out www.motionographer.com to see what kind of stuff AE is used for.
          Not sure if it has been mentioned but Andrew Krammer has a great resource over at videocopilot.net....his tutorials are excellent.
          Regards Dave.
          www.nakedeyedv.com
