After installing Edius, i used TitleMotion and it worked, then next time i want to use it, it will Show the word ''3) Dongle Error'' and Edius will Hang.
Any one with Solution to this
I am wondering why EDIUS would see the dongle and TMPRO does not.
Steve EDIUS Trainer, Grass Cutter Gold
After install before start. Edius should work for 30 days without a Dongle. As K said, it is strange that Edius sees the Dongle and TMP does not. After you check the HASP drivers and you still have the problem, I would reinstall TMP.
When i reinstall TMP. it works but when you close Edius and start again it starts the Error message Again, so i resorted to reinstalling and uninstalling to use TMP
Doesn't matter. EDIUS requires the dongle as a proof of license. When you install the software, you don't need the dongle. Only when you run it, it will look for the dongle.
