Please list which HDMI monitors you have tested with the HDSpark, HDStorm or HDThunder. Include the Make, model number, if you have tested it with HD and SD, which HDMI card you have, and if you are using NTSC or PAL. A web link might be nice.
Compatible HDMI Monitors for HDStorm/HDSpark
bejay
Primary - Gigabyte 890FXA-UD7 / AMD Phenom II X6 1100T / 8 GB RAM / ASUS Radeon HD 6850 / HDSpark / W7Pro64 / Edius 551 / ProCoder 2
Secondary - Asus P5Q DX / Intel Q6600 / 8 GB RAM / NVidia 8600GT / W7Pro64 / Edius 551 / ProCoder 2 -
Could someone let me know if the DELL range of 24" monitors work with the HD storm in SD & HD mode.
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.Comment
I just placed the benq E2200 HDMI monitor on my edit desk, plugged it in and WOW! It works fantastically well in HDV 1440x1080i PAL !!!!!!!!!!!!!! Mind you, progressive projects do not show up.....any help here?
MODEL: BENQ E2200HD series 22"
COST: $245
PIXELS: 1920x1080
WORKS: HDV 1440x1080 (and 1920x1080) 50i PAL 50 hz
SD 720x576 50i PAL 50 hz (but scales image to full screen)
AFTER EFFECTS: Awesome full preview, even scales qtr res down to qtr size within the screen (proof of 1:1 pixel mapping) I wish edius did the same for 4:3 and SD projects, but instead scales them up to full screen.
DOESN'T WORK: All the progressive formats
So for $245 AU, its awesome for HDV editing.
Hope this helps, I'm happy as :)When I go out, I wear my EDIUS T-Shirt.Comment
I rang DVC yesterday and I was told that the Viewsonic works in HD and SD.
Viewsonic VX2260wm 22" Widescreen True HD LCD Monitor
Don't have it myself so I cant say, but they sell the cards, build the systems and you would think they should know.Last edited by tony; 12-21-2008, 01:24 PM.Tony
Fractal Design Define XL R2 Full tower- Asrock Z490 Taichi - i9-10850K -- 250GB 860 EVO- 32GBVengeance LPX- Blackmagic IP4K-- Geforce GTX 1070 Founders Edition -- EVGA G3 850 PSU-- Corsair H100i Pro XT- LG Blu-Ray writer- MxM PCI-e Reader-- EDIUS X WG- Win 10 Pro 64bit.Comment
If you have a question, post in a separate thread. (And please use the search function!)Comment
ViewSonic 22" VX2260WM Wide 2ms HDMI TF works in PAL and will show SD material as well.E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB DisksComment
Bought a Sony Bravia 19" LCD TV. Model KDL-19L4000 as a preview monitor for my HD Spark and HD Storm cards.
Tried it with the HD Spark so far and all works fine with SD and HD. EXCELLENT picture quality, in both SD and HD.
Been reading on the threads that we should stick to 16:9. This screen is 16:10 and all is fine. It displays 16:9 with a very small border on top and bottom.
It is 1680x1050, 5.3 mega pixel and has a higher pixel/inch density than the 20" Sonys with 1366x768 resolutions.
Cost me £209 here in the UK. has 2 x HDMI slots and Component.
http://www.totaldigital.biz/index.ph...oducts_id=2872Raja Singh
Sadha Video
UK
Gigabit EthernetComment
Here's a good site to calculate viewing sizes on TVs
http://tvcalculator.com/index.html?a...43c4b97daf1273Raja Singh
Sadha Video
UK
Sony Bravia KDL26M4000 works in SD and HD monitor reports 720x480i and 720x480p[COLOR="Teal"]
Main System:
Edius WG 8.53, Alienware Aurora R7, 8th Gen Intel(R) Core i7,256GB M.2 PCIe Solid State Drive,(Programs ),2TB 7200RPM SATA 6Gb/s (Storage), 1TB Samsung SSD (Storage)16GB DDR4,NVIDIA(R) GeForce(R) GTX 1080 Ti with 11GB GDDR5X' 850W PSU ,Windows 10 Pro
2nd: Asus Republic of gamers Rampage 3, 6 gb, nVidia gtx, i7, win7, Edius WG 8.52 /w Spark card.
3nd: Dell precision mobile M4600 workstation i7, nVidia 2000m, Edius 6.08.Comment
" I rang DVC yesterday and I was told that the Viewsonic works in HD and SD."
This is true although it works at HD PAL sizes and 16:9 SD. It does not work at 4:3 SD.
Our tests with the BenQ 2400HD give a very good picture at HD (1920 & 1440 @ 50hz) but it does not work at either 16:9 or 4:3 SD @ 50Hz but appears to work with 16:9 SD 60hz (NTSC).
SD support on lots of HDMI monitor has been really poor with the Storm and Spark. The same monitors that will not work with the Thompson cards will work with the Black Magic cards. I don't know why right now.EDIUS silver certified trainer.
Desktop: 2Ghz 12 core Xeon processor, 32GB RAM, nVidia 1060, BM Intensity Pro, Windows 10Comment
Just letting everyone know that this monitor works fine with HDSpark:
Dell S2209W (22") or S2409W (24").
It is a 1920x1080 native display with DVI in (You will need a HDMI-to-DVI cable, which is very cheap). It plays 1080/720/480 (although 4:3 is stretched to fit the screen). I went through 3 monitors and found this one to be a good one. There is no 1:1 pixel mapping, though. The HDSpark outputs 1920x1080 or 1280x720 so even your 1440x1080 HDV stuff will go out as 1920x1080. DVCPROHD 1280x1080 / 960x720 also works fine.Comment
