Which dvd authoring software is better for edius sp
  • Which dvd authoring software is better for edius sp
    Hi i want to create my personal dvd menu without using any template, before using the edius sp i owned a matrox cacpturing card and i used to use the reel dvd program, now i dont know which software is better for my new edius.
    Oh and by the way, i tried to use the reel dvd with edius made files and it does not work, so i assume that it will be better to buy new dvd software authoring software.
    It's been a while since I used Reel DVD, but I'm not aware of any incompatibilities with our MPEG data in past experience.
    What settings are you using to export?
    As for alternatives - if you're coming from a Reel DVD background, you might want to look at DVDLab. I understand that it employs a bit of the same 'flow chart' type of authoring that Reel DVD lives on (in terms of constructing your disc's navigation).
      Reel DVD and DVD Lab Pro require elementary streams, Edius can't do these
      you have to use ProCoder or ProCoder Express or Tmpeg4 Xpress
        Reel DVD, at least last I remember, also requires that any MPEG audio has the CRC (aka Protection) enabled.
          luckily mpeg audio is no longer a valid DVD audio format
          it is also slowly being dropped in PAL land
          already dead in NTSC land
          ac3 or wav is the go
            well guys thanks for the answer, fist of all tell you that i have tried to export in mpeg2 straight from the edit line, didn't work; then exported a dv file and used the procoder to make it mpeg2, didn't work, then used the tmpgenc 4.0 didn't work.
            and every time I take my mpeg2 file (always demultiplexed) to the reel dvd it collapses.
            I assume that it is better to work with another dvd authoring software, but which one?
              I use DVD Lab Pro www.mediachance.com
              It is easy to use, cheap and a 100 x better than Reel DVD (and I have used Reel DVD in the early days)
              check the "quick tutorial" section of the manual
                There is something wrong with your workflow, I use ProCoder and Reel DVD before and it works just fine.
                  edius 4.6 and after AE CS3 wrol fine for me, the problem is occured when you upgrade the edius to 4.61 so im stack on 4.6
