Audio Mixer /BEHRIGHER BCF-2000
  • Audio Mixer /BEHRIGHER BCF-2000
    here I leave a video demo where the action is in audio mixer Behrigher BCF-2000 in EDIUS:
    Hardware Plug-in for EDIUS, Audio Mixer / 8 channel audio mixing
    additionally here is to download the same video with better quality as a Windows Media Video
    that they find the mixer ... greetings to everyone.
    CSXD2 l For EDIUS Pro 6.5
    Crazy-good video!
    Is your computer performance effected by the BCF-2000?
    (we know about the mixer sluggishness... is there a difference?)
    How is the BCF-2000 with 4.61?
      Originally posted by Rusty
      Crazy-good video!
      This video download the demo on a page editor EDIUS in Japan, Rusty actually the BCF-2000 works with all the normal functions of Audio Mixer in Edius 4.61 ... greetings
        to be honest there are lost of problems between Edius and the BCF.
        I have one.
        If you are used to mixer control in audio apps you will certainly pull your hair when you hook up a bcf 2000 to edius.
          I have a JL Cooper Fadermaster 4/100 which probably exhibits the same sort of problems as the BCF. Mixer control surface integration in Edius is almost there, but not quite. The software designers would do well to look at how this is implemented by Av*d.
          Andrew Pinder
          www.chpv.co.uk
            I'm not surprised. I worked for Behringer in Willich Germany for a short while. Their equipment today is substandard (made in China to the lowest bidder) compared to the equipment made in Germany many years ago. Uli Behringer is constantly looking for the cheapest parts to use as well.
            I was very unimpressed by their tech. department and research team.
            JL Cooper is at the other end the spectrum... very well made and professional.
            John Glantz
              Hi,
              I have just now wanted to buy a BCF.
              Is there any alternative under EUR 1000,-
              I should have a device being compatible also with Samplitude...
              Thanks,
              I
                Does anyone have real-world experience with the Behringer BCF-2000 as what it will do in Edius? If it actually will adjust audio levels via the faders rather than mousing up & down, I'm willing to try it. If it will adjust audio levels, do the faders' positions then jump around on playback to reflect the adjusted levels? In other words, is there feedback from Edius to the Behringer?
                Also, can the faders or knobs be used to adjust other things, like video levels?
                  Hi,
                  I have just now bought a BCF2000.
                  Even though it is not optimised yet, I can already make the followings:
                  - Adjusting Volume (There is also a feedback from the faders)
                  - I can choose the channels (nothing, touch, write etc)
                  the four buttons in the down-right corner:
                  - I can switch on/off the Edius-mixer
                  - I can stop/start the video
                  - I can play the video forward and backward (with different speeds)
                  These four buttons can be changed on a free way. (You can choose the propern command in Edius (Plug-in / BCF2000)
                  If I know well, you can choose the potmeters (the first button raw...) to set balance. It does not work at me yet...
                  Please download the application "BC Edit" from Behringer and install the JRE 1.4.2_3 from Sun. This is a very good preset editor for BCF2000. It can happen it allows you to set up your BCF2000 on a better way.
                  It makes sense anyway to make audio in an other application.
                  I use Samplitude 9.12 Classic. It supports BCF200 on a much better way. It makes no sense to get mad in Edius. Make everything about audio on a special application..
                  Regards,
                  I.
                    thanks for the info...Its really helpful
                    mortage calculator is available for mortgage calculations.
                      I notice Caminostereo is running the BCF2000 on a Vista x64 machine.
                      I have just confirmed with Beringer that there are NO Vista drivers let alone 64 bit ones.
                      Are you just running the mixer with XP drivers and hoping for the best? This could be part of the problem.
                      I think I will wait until Vista drivers are available (they are not even in beta for this piece of hardware yet)
                      Main Editing System: Sinclair ZX81 0.75Mhz chip (Overclocked to 12Ghz), Liquid Nitrogen Cooled. 48k of RAM, Compact Cassette tape drive (9600 baud), 4" B&W monitor. No keyboard - all input by thought transfer from a colander on my head. Gives me 180 layers of 4k in real time (all with 3D PIP added) and can encode and burn a 2 hour Blu Ray in just under 12 seconds. Custom editing chair that floats on magnets 2 feet above the floor. I am also able to travel in time.
                        This is not the problem the bcf2000 works just fine is vista 64.
                        All apps can use it.
                          All apps can use it even Edius.
                          Now witrh hold state on the Edius mixer it even got a bit better.
