I built a new machine, Edius X is working perfectly, intel graphics working perfectly...Asus z790 Hero, only M.2 and raid ssd, rtx 3070ti, 128gb ram Kingston Fury Beast, 1300 watts power supply, EVGA Nu audio
Edius X 13900k
Tags: None
Very Nice!!
Like you, my 13700K build has been running for 3 months without issue. I know there were reported problems
with 11th, 12th, and 13th gen chips. While there may have been inherit issues with the early versions, I do know of users with
12900k systems that have not experienced problems either.
I fully believe it comes down to build quality and parts used.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD. -
I have been running a 13900K for a little time now and it is the processor I have been waiting for all of my editing career. Everything is peppy. Exports are very fast. I can edit 1080p60 10bit P2 footage in multicam with the filters on and it chews right through it. If I render out HQX files and put them back on the timeline the experience is smoother than butter so to speak. I had 90 minutes of five tracks of HQX 1080p60 material on my timeline. In multicam I zoomed out so the full 90 minutes was showing and I can scrub the mouse as fast as I can move it and all five windows look like they are showing every frame that goes by no lag or hickup! (this is being played from an NVMe RAID) :) It is insane when I think back even ten years from where we were.
I have not even hooked up Quicksync as it is not needed. Thanks again to Jerry for the computing wisdom.Asus PrimeZ690A - Intel i9 13900K - 32GB RAM - NVidia GTX1070 - Edius X WG - BM Intensity 4k - Boris RED - Vitascene 2 - Windows 11Comment
I still get problems if I enable quick sync decoding on 11th 12th and 13th gen systems but even without that performance is a lot better than older chips.EDIUS silver certified trainer.
Desktop: 2Ghz 12 core Xeon processor, 32GB RAM, nVidia 1060, BM Intensity Pro, Windows 10Comment
I used the 9900k, but I only had one version of Intel Graphics that I could install and enable, already on the 13900k, even doing the intel graphics update, everything works perfect, Edius X 10.34.10936, it's perfect on the Asus hero z790, a detail, the same format in Adobe, makes the CPU heat up more, Edius preserves the temperature more and renders faster.Comment
Just to balance this post for anyone casually browsing the forum who may not be aware of particular Edius and QuickSync issues.
As David Clarke has already mentioned, yes there still are problems.
I recently built a powerful system for a friend on Linux who’s using another NLE. This was a powerful 13th Gen, Nvidia 40 series, Z790 and DDR5 build.
During the build I tried Edius X with it. This was the by far the best performing Edius system I have ever used for particular codecs. Running HQ/X and certain other intra-frame codecs, it was absolutely awesome. However, there were still issues with QuickSync, which obviously makes the use of certain workflows with certain codecs problematic.
Jerry may believe that these QuickSync issues are down to the quality of the build but that is not the case.
GV acknowledged some time ago that there was an issue with Edius X after a certain point with Intel CPUs and their iGPUs, as far as particular QuickSync usage was concerned. As far as I’m aware, I have never seen GV acknowledge a fix to this issue. I’m not saying that GV have never acknowledged a fix, I’m just saying that I’ve never noticed any acknowledgement. However, I’m not as up to date with Edius as I once was, so may have missed such an acknowledgement.
Also, given that very experienced system integrators who definitely know how to build an Edius system and who would be using quality parts, such as David Clarke, are still experiencing certain QuickSync problems. I think it’s accurate to say that certain QuickSync issues still exist with 13th Gen Intel and Edius X.
I also experienced particular NVENC issues that I’d already mentioned and documented in the past.
So my conclusion is that a powerful current Intel/Nvidia build for Edius X will still have particular problems, which I think fair to now class as legacy issues.
However, for anyone working with HQ/X and a number of other codecs. You will definitely find any 13900K build to be absolutely amazing for Edius X. And any particular shortcomings with the decoding, rendering and processing of certain inter-frame codecs will probably be less noticeable compared to what it was, due to the software processing power of the 13900K.​
Is your Robot three laws safe?Comment
I have not had one single issue with the iGPU drivers with my [email protected]. Pat built a 12900K for his daughter who also has not had any issues.
I get realtime playback with H.264/H.265 as well as HQX and Prores. I use the system in 3840x2160 59.94p 10bit projects with matching clips. My editing drives are all PCI-E 4.0 M.2 NVME's. The project folder resides on a WD 850X with up to 7300MB/s read speeds. With 64GB of DDR5 ram.
I have a push pull set up on my 360mm AIO
which help keeps things cool.
There still may be issues, but I haven't seen them.
I wouldn't be discouraged from building a 13th Gen system with quality parts. Yes, quality parts, especially the motherboard and power supply. The 13th gen chips require the power and a 20+1, preferably a 24+1 power phase capability for the 13700K and 13900K chips would be prudent. A high end Platinum or Titanium PSU will handle
the continuous power needed as well as the transients.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
In the end, I went with:
MSI MPG Z690 Edge (slot compatability for cards was the biggest deciding factor)
13900K
G.Skill 64GB DDR5 6000 (PC5 48000) CL30 (F5-6000J3040G32GX2-RS5K)
Fractal Define R5 case
Fractal Celsius S28 (larger would have meant having to remove 5.25 bays in my case and I need those for a disk burner and a DCP drive bay)
Mellanox ConnectX-4 for SAN connectivity (all video assets)
1 x 4TB nvme (local assets)
2 x 2TB nvme (dual OS for Win11 and Linux)
Corsair RM1000
MSI RTX3060Last edited by BernH; 07-05-2023, 10:54 PM.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX Titan Black 6GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX and one on Intel HD4600).Comment
My only suggestion is to read up on the undervolting process. This one process will allow you to keep your thermals in check.
Fortunately, many MSI undervolting videos are available on YouTube. The MSI process is fairly straight forward.
You can also use the Intel Extreme Tuning Utility. The auto setup usually reaches for the highest speed and doesn't always get the most balanced settings to prevent thermal throttling.
Have fun with the build.
I have had good results with undervolting. This is a hot chip no doubt but if you can scrub off some power it can stay in the 70s at stock. Overclocking and undervolting would be the best and I have had some success with this, but then after some updates lost that gain. I am not an overclocking genius, but I would like to get 1 or 2 cores at 6 or 6.1 GHz. Will be a project going forward.Asus PrimeZ690A - Intel i9 13900K - 32GB RAM - NVidia GTX1070 - Edius X WG - BM Intensity 4k - Boris RED - Vitascene 2 - Windows 11Comment
I got the system put together last week and have been picking away at software installs.
As you noted, this chip does run hot, and is reaching mid to high 80's C on a burn-in test, even with the water cooler. I have looked at some recommended undervolting amounts people have posted and they range from a differential of -0.05 to -0.1.
If you don't mind me asking, have you played with different voltage differentials, and if so do you have a recommendation? I was thinking about starting in the middle of that range at -0.075 and see how it looks from there.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX Titan Black 6GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX and one on Intel HD4600).Comment
Hey Jerry,
in your signature it says Corsair H110i, is this correct, is so that is 280mm and should be ok
the real test is to export from EDIUS timeline to Prores 4:2:2 and see how hot it gets, possibly only mid 60sAnton Strauss
what size is your radiator and what is the make and model? 280mm should be minimum for that CPU, ideally 360mm
The cooler is a 280mm. As is also noted, I would have preferred a 360, but I didn't have the space for a larger one because it would have meant giving up the 5.25 bays and I needed those for a burner and DCP drive caddy.
Anyway, even hitting the temps I just mentioned is well within the specs of that CPU, with 100 C being it's thermal throttle point from what I have read, but if a little undervolt can knock several degrees off and not really impact performance, it's not a bad thing.
I'm not using only Edius to test this, as the system will be doing more than edius work, so I used passmark burn-in test with a 90% load on the CPU and other components so I could also test and monitor the other components also. All is working good, but Jerry recommended looking into undervolting for that cpu so, since it's my first build with this beast of a chip, I took his advice.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX Titan Black 6GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX and one on Intel HD4600).Comment
Bern, you said you were in the 80c range. Those temps are not bad on a benchmark test. What is the chip speed? If you are running at 5.8GHz, that is not bad at all.
On the MSI, it appears the CPU Lite Load setting can do quite a bit. https://forum-en.msi.com/faq/article.../cpu-lite-loadLast edited by Jerry; 07-25-2023, 01:46 PM.Jerry
