Asus ROG 16 with SSD portable hd
  • Asus ROG 16 with SSD portable hd
    This computer came with only one 500 GB SSD drive. I wanted/needed another drive to store files on and leave all programs on primary drive. I purchased the ScanDisk 1TB portable SSD with USB C. Prior to adding the new drive speed was not an issue. When I moved all the Edius and Mync storage files to portable drive the computer seems to be slower with some hickups.
    Thoughts on how to improve speed and workflow.
    Specs: ASUS ROG WUXGA 144hz gaming laptop. Intel Core i7 Processor 11th gen; memory 16GB NVIDIA GeForce RTX3050 Ti; 512 GB SSD
    run a speedtest on the external SSD
    you could have added a second Samsung 2TB or 1TB NVME SSD inside which would do over 2000MB/sec
      The C: shows write speed avg 1.15 gb Read avg 646
      D:external SSD write speed avg 384 mb and Read avg 264
      E: write 114 read 206
        Anton as always you know what you are talking about. After running the speeds I returned the external SSD and installed a 2TD Samsung SSD 870 QVO internal hard drive. Not as fast as you suggested but doubled what I had
          The QVO is the lowest performer of Samsung, but the cheapest
          Pro would be best followed by EVO
          what is the E drive? an external spinning drive?
            I actually got this drive Samsung - 980 PRO 2TB PCIe Gen 4 x4 NVMe Gaming Internal Solid State Drive
            yes the E drive is external spinning
              The 870 I originally mentioned would not fit so the much better upgrade
