Older system and edius versions
  • Older system and edius versions
    Hi all ! long time dvstorm / eduis user from 2008 looking to start editing again. I'm beginning to gather info on new system specs etc. Before I'm ready for that probably will dust off my old PC, capture some old DVCAM tapes and start getting back in the flow.
    Edius 5.5
    i7-860 ( I think) 2.6G , 6G triple channel memory
    PnY quardo fx1500
    Windows 7
    Will upgrade to a current SSD drive
    what version of Edius should I start back with that's closest to the latest in terms of settings, filters, workflow etc. I only ever captured video with my DVstorm card, what could I use now as a substitute? I might pick up a used one for this, up until what version will it still be recognized? Does Boris Red still plugin to Eduis ?
    Win 7 or win 10
    Looking forward in getting to know and learn from the community, have a long journey starting from scratch! Thanks
    in order to capture DVCAM, you need to get EDIUS 9 as EDIUS X no longer supports DV Capture
    I would get Win 10
