Video Capture
  • Video Capture
    I am running Edius 7.53. For some inexplicable reason I can no longer capture video input from external devices, e.g. VHS player. I click on the 'Capture' tag, select input device and the following 'reel number' window. The capture device window opens and plays the input video then when I click on "Capture" (F9) the 'Capture' window opens but the red bar, indicating capture in progress, does not light up. As far as I am aware I am using the same hardware device preset that was entered when capture did work. I don't know what's gone wrong. Looking for suggestions.
    Maurice R Fleisher
    Verify that the capture device is still seen by windows. Check the device drivers as well.
      can I see your capture device settings
      also, are you capturing PAL or NTSC VHS?
        Capture device settings attached. Capturing PAL only.
        Maurice R Fleisher
          set video format to 720x576 50i
          in output tab, choose "not select"
            My video format was already set to that and the only suggested change to the output tag made no difference at all. Still no red capture bar. I have used somebody's AVDC-55 as a capture device using those same settings on this same desktop and it worked fines so it is only Edius which is at fault. Any more suggestions?.
            Maurice R Fleisher
              If you haven’t already tried these here’s a couple additional suggestions.
              1) Make sure where you are capturing to has room or is valid/seen by the computer.
              2) Have the capture device connected and on.
              Reboot computer.
              Relaunch Edius
              If still unable to record:
              Make a new preset device like capture 2 or test.
              Good luck and may the zeros and ones be with you.
              Main - Edius Pro 9.55, Windows Pro 10 20H2, Lenovo Ideacentre 720-18APR, AMD Ryzen 7 2000 8 core 3.2 GHz, Radeon Rx560 4096 MB.
              Dub - Edius Pro 9.55, IMac Windows 7 bootcamp, Sony MVMC-DA2 DV converter, Sony BVU 800, Sony BVW, Sony DCR-PC101, Sony GV-D800, Alesis MultiMix 8.
              Old Cam - Panasonic HVX200 (DV100_1080/59.94i), AJ-PCD-10, P2 F series cards.
                Thanks for that but Edius is playing games with me. Capture has suddenly returned, I guess from cyberspace. I did nothing new other than swear. Perhaps banging the desk really hard did it. Don't you just love computers!!
                Maurice R Fleisher
                  Sometimes, simply the cable can be the issue. Jiggling it or using a replacement is a good idea, to eliminate that as a cause.
                  Regards,
                  Jon
                    I have been using Edius 9 and I have the same problem with capture. I have to toggle to another capture method then back to the one that works to get things going. Kind of a work around but that's all I've been able to figure out.
                    Ken
