Older laptops with firewire 400 connectivity?
  • Older laptops with firewire 400 connectivity?
    Hi all - this is an odd one.
    I've got a bunch on minidv tapes that I need to convert to preserve them. They need to be played via the camcorder (or deck) and connected via firewire 400. The tower that I had build for editing had a firewire port in it but that was quite some time ago.
    I'm on the lookout for an older laptop that has ieee394 connectivity. The only one I can find is the HP elitebook 8450p (and I only know that because I used to own it)
    Does anyone recall any other models that shipped with this connectivity?
    why don't you add a firewire card to your main PC? make sure it has a VIA or Texas Instruments chip and if FW400
      I edit solely off a laptop now and sadly the main editing PC I used to use that had firewire connectivity is no more :(
        If your laptop has a PCMCIA slot you can get a PCMCIA firewire card to add to it. If not, perhaps a blackmagic usb shuttle and use the s-video analogue out of the camera or deck? S-video is almost the same quality as a direct firewire connection providing you use a good s-video cable.
        You may have to settle for used for both of them as the shuttle is discontinued and I believe most manufacturers have discontinued PCMCIA firewire cards as well. You would likely have to settle for a used laptop too if that is what you prefer as firewire in general has been abandoned for the most part.
          Hmmm...thanks for that - good ideas.
          No PCMCIA slot in the laptop unfortunately so that's a no go.
          The tower that I used to use (with FW400 built into the mobo) won't power up any more and the graphics card is heavily rusted, along with whatever else I can't see visually (!). It was ready for the trash, but I'm thinking that I may have to try and revive it to get these tapes backed up.
            In the past I have used a Thunderbolt port on a laptop with Thunderbolt-firewire adaptor to capture. Using this I could capture but not record back to tape. Thunderbolt laptops do cost more, however, so it may be cheaper just to get a second hand desktop and put a FireWire card in it.
              Hi David, re In the past I have used a Thunderbolt port on a laptop. Is there any particular type you recommend with Win10 compatibility?
              Jim
                I have not done this for a couple of years - I used to make a lot mor systems and had more new stuff with which to play. We would generally buy the FireWire-Thunderbolt adaptor from Apple, which at the time was thunderbolt 2, and a thunderbolt 2-3 adaptor to go with it. This was all with Windows 10. This was a couple of years ago so I guess there is a possibilty it does not work any more.
                  Hi....I have a bundle on minidv tapes that I need to change over to safeguard them. They should be played by means of the camcorder (or deck) and associated through firewire 400. The pinnacle that I had work for altering had a firewire port in it however that was a long while back.
                  I'm keeping watch for a more established PC that has ieee394 availability. The only one I can discover is the HP elitebook 8450p (and I just realize that since I used to claim it)
                  Does anybody review whatever other models that transported with this network?
                    you buy a $50 firewire 400 card with Texas Instruments or VIA chip and insert it into any PCI-e slot and you are done
                    and you need EDIUS 9 or earlier in order to capture
