BMPCC 6K PRO gives monitor signal only at 50 fps
  • BMPCC 6K PRO gives monitor signal only at 50 fps
    Hi everyone,
    is there anybody out there who knows what could be the reason that I can get no monitor signal connected to a BMPCC 6K PRO. Only if I set 50 fps it works. Not any other framerate (24, 25, , 29,97, 30 etc) will deliver a signal.
    What seems very strange is, that it is the same issue with both of our BMPCC.
    Any idea??
    Nicola
    defacto.media
    www.defacto.media
    __________________
    Win10 SSD || Intel(R) Core(TM) i7-6820HQ || Intel(R) HD Graphics 530 / NVIDIA Quadro M2000M || 64 GB RAM || Edius 10 WG
    what is your project setting
    and what is your EDIUS 9 WG version number?
    and what is your BM driver version?
    and what is the connected monitor?
      Anton, I meant from the Cam to the monitor. Edius has no part in it. Since I got no feedback from the BMD Forum, I thought I would try it here.
      Same with our video mixer Roland VR-4HD. It only receives a signal when the BMPCC 6K Pro is set to 50 fps.
      There must be some profound reasons which go beyond my imagination.
      BMPCC Driver Version is latest 7.3.1
      Sensor area is set to 6k (camera settings) which could probably be the reason. Although the problem is also in FHD and most likely in any sensor resolution.
      Nicola
      defacto.media
      www.defacto.media
      __________________
        at least 50 fps is a correct frame rate for your region and matches the 50 hertz frequency of light
        what is the TV monitor you use, maybe it can't handle the other frame rates
          The resolution set in the camera does not matter because the Pocket only sends 1080 through the hdmi, even if your recording settings are 6k the hdmi out will only be 1080.
          so I would think your monitor is not supporting the frame rate. Try other frame rates like 25 fps and se if that works.
          JoiCam´s
          And more
            "Try other frame rates like 25 fps and se if that works".
            Actually no other framerate than 50 will show up in monitor and in Roland mixer.
            But thanks Anton and Johannes. Will do some testing and report back.
            Nicola
            defacto.media
            www.defacto.media
            __________________
              Ah I see, I misread your post.
              Is this a computer monitor or video monitor?
              What monitor is this?
              JoiCam´s
              And more
                It is a video monitor (Lilliput / 1080p).
                But same behavior happens on the video mixer. And the technical specifications are supporting any frame rate. As I said, I have to test some more visual devices.
                Nicola
                defacto.media
                www.defacto.media
                __________________
                  Originally posted by nictau View Post
                  ...I have to test some more visual devices.
                  Meanwhile I found out that the video mixer specifications were the problem. But thank you guys for your willingness to help.
                  Nicola
                  defacto.media
                  www.defacto.media
                  __________________
                    Good to hear
                    JoiCam´s
                    And more
