Please fix the problem I raised,thanks!
Although we may have language barriers, but I try to express clearly.
I have asked many times and no reply from developers. I upload videos to Youtube and files to Google cloud disk. You can test them.
Japanese and Chinese camera manufacturers are basically H264 and hevc packaging formats, decoding is really important.
Video preview address: https://www.youtube.com/watch?v=QYHCUrsAN54&t=147s
Video Project and File download address: https://drive.google.com/drive/folde...IT?usp=sharing
My computer configuration is good enough,However, the performance of ediusx is far worse than that of edius9 (cpu:i9 9960x 128G RAM Gpu:Vega64)
Such a good i9 cpu computer EDIUS performance is not as good as i5 cpu.
This video shows everything, and I'm really disappointed with the purchase of ediusx. V4 transition and audio filter can be installed to 9 or 8.53.
Background rendering is the function of Da Vinci and Premiere long ago. Let alone develop more functions, The subtitle tracking function of ediusx is nothing new. Dark background edius8 and 9 can be adjusted.
1.when will EDIUS start to develop AMD NVIDIA GPU decoding and coding function?Intel's Intel's Xe DG1 graphics card is a failed product, which is not compatible with Xeon and AMD platforms.EDIUS can't go down like Intel.
2.The video in the Media pool window cannot be previewed thumbnail by sliding the mouse left and right. Why take the trouble to do that? Press middle mouse button, which is inconvenient to press,Can it be improved?The thumbnail does not support the acceleration function of the graphics card, and the response is slow.If the thumbnail display can be synchronized to the preview window, real-time response is a very good improvement.
3. I hope to add the lost frame playback function in the normal mode, which is also a simple way to improve the performance of EDIUS. The multicam mode already has this function.
4. Sugges: Click transition or Effect to automatically cycle preview at the pointer position. Double click transition or Effect to automatically add it to the pointer position. Drag the timeline to continue playing without stopping.
5. Suggest: addingTime line video left and right exchange function,Greatly improve editing efficiency.
请工程师回答我5个问题,谢谢!
虽然我们可能有语言障碍,但我尽量表达清楚。
我已经问了很多次,但没有得到开发商的回复。我把视频上传到Youtube,把文件上传到Google云硬 盘。你可以测试它们。
日本和中国的相机厂商基本上几乎都是H264和hevc的包装格式,解码确实很重要。
视频预览地址:https://www.youtube.com/watch?v=QYHCUrsAN54&t=147s
视频工程和文件下载地址:https://drive.google.com/drive/folde...IT?usp=sharing
我的电脑配置很好,但是ediusx的性能比edius9差得多(cpu:i9 9960x128G内存Gpu:Vega64)
如此好的i9电脑EDIUS性能不如i5。
这个视频展示了一切,我对购买ediusx非常失望。V4转换和音频滤波器可以安装到9或8.53。
背景渲染是达芬奇和Premiere很久以前的功能。先不说开发更多的功能的事情了,ediusx的字幕跟 踪功能并不是什么新鲜事。暗背景edius8和9可以调整。
1.EDIUS什么时候开始开发AMD NVIDIA GPU解码和编码功能?英特尔的Xe DG1图形卡是一款失败的产品,与Xeon和AMD平台不兼容,EDIUS不能和intel一样没落.
2.左右滑动鼠标无法预览素材窗口中的视频缩略图。必须多此一举的点击鼠标中键然后,然后左右滑动鼠标预览 缩略图,这是非常 不方便的,可以改进吗?缩略图预览不支持显卡加速功能,响应很慢。如果缩略图显示可以同步到预览窗口实时响 应是非常不错的改进。
3.我希望在普通模式下添加丢帧回放功能,这也是对EDIUS性能提升的一种简单改进,多机位模式早已经有 这功能了。
4.建议:单击“转场”或“特效”可在指针位置自动预览。双击“过渡”或“特效”可将其自动添加到指针位置 。拖动时间线继续播放,而不是停止播放。这个功能从来都不起作用。
5.建议增加时间线素材位置左右交换的功能,极大提高剪辑效率。
请工程师回答我5个问题,谢谢!
