New build Z490 Taichi and 10850k
  • New build Z490 Taichi and 10850k
    Hi Guys, thanks for all the advice about the components for my new Edius X build.
    It only took me a couple of years to gather most of them up :) but got there eventually.
    I went for the Asrock Z490 Taichi and 10850k
    32GB Vengeance LXP
    EVGA 850 G3 PSU
    860 EVO SSD
    H100i pro XT
    EVGA Geforce GTX1070 ( I bought this about 2 yrs ago)
    Blackmagic IP4K
    I have my MxM PCI-e Reader i need installed too.
    I will start the new build in a few days time and wondered will I need to update anything in the bios before I start?
    I will look for the XPM memory setting and maybe apply that. (anything else while I in there ?)
    I bought the MB at the end of October 20 BTW.
    Any help and advice will be greatly apricated :)
    Thanks in advance.
    UPDATE to above post, I've the build complete now.
    Tony
    I was making a file for Handbrake from a 3hr HD timeline. Are my temps very high? if so would someone advice a setting change in thr BIOS :)
    Thanks in advance.
    Tony
      do you hear the radiator fans speed up during export? If not, maybe your pump and power for radiator fans are not connected properly or the waterpump is not fully tight, use a Phillips head and not fingers. Or your Bios setting for the fan header temp sensing is incorrect, it should be set to CPU so that fans speed up with the CPU temp
      did you leave the stock thermal paste on the pump or did you use third party
      I use the stock paste and never had an issue and my temps usually go to 60C during long exports with 100% core usage
        Well, I had the waterpump screws just hand tight but now I did use the screwdriver and they did tighten more till all 4 tight now.
        The waterpump RGB is lite and two top case fans are working.
        I will try and check out.. Bios setting for the fan header temp sensing...
        Turned out , I had to use a third party paste because I tried fitting the waterpump a few times making sure I used the correct size standoff screws that the stock paste was smugged , so I removed all paste and used thermal grizzly and only used a very tiny amount and used the wee spreader supplied.
        I had a look around the net and I came accross a post saying, if bios kept at auto volts temps will be high but I wouldnt know :)
        Attached Idle temps from this morning.
        Thanks Anton for your time.
        Tony
          I'm just after changing CPU Fan 1 Setting from Standard to Full Speed, matbe preformance might be best?
          Tony
            there is no need, I have mine set to quiet
            the fans must speed up automatically when temps increase
            so if you start an export, the PC is quiet and as the temps increase, you should hear the radiator fans speed up and produce more noise
            can you confirm you connected to waterpump header, see attached
            in the BIOS, you can then set the waterpump cpu header to quiet or normal
            I do not recommend using the Corsair software, I don't even connect the USB to the pump
              Yes, thats the same header I'm connected to and Naw, I didnt bother with the Corsair software either, I've no interest in RGB.
              The best change I made was to use the screwdriver to tighten down the waterpump as you recommended, and when exporting I do hear the fans crank uo more.
              What voltage is you CPU set at? is it still set at Auto?
              Thanks Anton for you great advice. :)
              Tony
                I leave the voltage on auto
                  Ok Anton,thank you.
                  Tony
