Hi, I already bought a new 13" Macbook Pro m1 chipset but I can't install Edius X or older versions. I tried lots of programs, virtual server or emulgator. How I can Install Edius in my MacBook m1 Chipset.
I would not be surprised if it won't work. The processor is no longer the same type for which Windows was written. Is there even a bootcamp for these new MACs?
EDIUS silver certified trainer. Main edit laptop: DVC Kaby Lake desktop processor laptop, 32GB RAM, 3.5Ghz i5 desktop processor, nVidia 1060, Windows 10. Desktop: 4Ghz 9900K processor, 32GB RAM, nVidia 1660TI GPU, Windows 10. Desktop: 2Ghz 12 core Xeon processor, 32GB RAM, nVidia 1060, BM Intensity Pro, Windows 10
Bootcamp allows dual-booting an alternative operating system, typically Windows, on Intel-based Macs -- that won't work with M1-based Macs because they are based on a ARM architecture rather than x86/x64. Virtualization solutions also won't work because they merely allow access to the processor from virtual machines. What's needed is a high-performance x86/x64 emulator that runs on the M1 processor, and Parallels is working on one.
Edius runs on Windows. Windows is designed for x86/x64 CPU's, as is Edius by default. Even if you can get Windows to install on one of those ARM processors or in an emulator, the CPU's don't have the same instruction set built into them, so it is very likely that any software that requires direct access to these instruction sets, such as AVX/AVX2, like Edius and just about any software that needs direct hardware access for performance will not be able to install and/or run on these CPU's.
Edius WG 9.54.6706, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
The M1 uses integration between CPU,GPU,RAM and SSD to gain its performance. Any software will need to be aware of these optimizations. For instance there is a special version of Resolve 17 for the M1 products. NLE's that already run on Mac have only just started to be altered for the M1 so I think EDIUS is a non starter on the M1.
Bootcamp is not working on m1 macbook pro. Crossover 20 is not working properly with edius. I tried Parallels Desktop 16 for M1 Mac Technical with Windows ARM 64 bit but when I run set up It can't extract setup files properly. Anybody has got a idea for setting up edius ?
