Mike, to first answer your question of quick placing colour grades on clips in Resolve. You save a still from the clip you like( right click on image in preview monitor Grab Still it will them appear in the gallery top left )), select another clip on the timeline in the colour page, right click on that still in the gallery and hit Apply Grade. Do this for as many as you like while in the colour page. Yes Resolve is different to most of the other NLE's for sure. In Resolve 17 lots can be done now in any page. The upgrade cost to the Studio version that gives a lot more capability is still a lot less than an upgrade of EDIUS.
Back to EDIUS. I think I have convinced myself that until EDIUS catches up with all the other NLE's to use multicore/threads and GPU it will end up looking slower and slower in comparison. Lets hope we get that in the next update.
Storage will be come more important so available PCIe lanes will be the key. For instance I can make Resolve on my PC seem slow,close to EDIUS by placing ALL files on the 6T hard drive and turning off GPU decode ( only available in the Resolve Studio version ). If I need to use a lot of pips etc the files need to be on the NVME drives. This requirement immediately puts AMD ahead of Intel for reasonably priced systems and for expensive systems Threadipper just crushes Intel anyway on all accounts. For the ultimate at the moment the latest Threadripper and NVIDIA GPU is king. For a turnkey system the Threadripper Pro. Maybe that will be available to everyone shortly too.. Going down the line the RYZEN 3950X is likely a good choice with PCIe add in card for extra PCIe 3 NVME drives though I still think Threadripper is a better choice for the extra PCIe lanes available to the motherboard. If GPU assist is available not sure a high core count Threadripper will be needed 24 core should be ample since a lot of the work should be done by the GPU. Another reason Resolve Studio has the advantage of using multiple GPU with assigned functions. I hope EDIUS moves in this direction too
No PCC does not run well needs to be off for editing then I turn back on for export.
