BM Intensity Pro 4K-Einstellungen in EDIUS X
  • BM Intensity Pro 4K-Einstellungen in EDIUS X
    Ich benötige die Vorschaueinstellungen für Intensity Pro 4K in EDIUS X Workstations.
    Kann jemand bitte helfen?
    Die BM Intensity Pro zeigt automatisch an so wie die project einstellungen sind, zum beispiel 3840x2160 at 25p oder 1920x1080 25p oder 50i
      Where in the Control Panel is Intensity Pro 4K registered, what options must be set to display picture and sound on an HDTV.
      No Tv-Preview, in DV-Resolve already:
        can I see a screenshot of project settings with all settings visible
        also, you can tick as seen in attached if the card does not support a frame rate or size you selected
          This does not work if you put UHD-Video material into an FHD-Timeline.
            I need to see a screenshot of your project settings
            also, you must use BM desktop driver 11.5.1
              I use the latest driver 11.6
                uninstall it and install 11.5.1
                still waiting for your project settings screenshot
                  I have saved the suggested driver. But for the time being I won't change anything,
                  because everything works except for the special case UHD video in FHD timeline.
                  I will possibly use a different workflow.
                  Thanks for your dedicated help!
                    UHD clips in HD timeline must work, don't give up so easy
                    once I see the project setting I can tell you the cause of your issue
                      Dear Anton, I now know for which video card driver EDIUS X has been compiled, I also found an error in the project settings.
                      Everything is running fine now!
                        Anton, just FYI, I am using 11.6 drivers on 1 machine with no problems for external viewing. Note that I don’t do any capturing. And I am aware of previous discussions about the drivers ;-)
                          if you are viewing via HDMI, you won't have any issue with 11.6
                          there are some analog audio issues with 11.6
