I stand to be corrected, but the original BM IP should work if the IP4k works, simply because it is the same driver software.
You are absolutely correct!!!!!!
1) If you have an Intensity Pro with old software installed, physically remove the Intensity Pro, and uninstall all related BM software from your machine.
2) Download and install BM Desktop Video Installer v.11.5.1. I found it here: https://blackmagic-desktop-video.en.lo4d.com/windows
3) Restart your system, and make sure the software installed okay. Shut down your system.
4) Physically re-install your Intensity Pro.
5) Start your system with your ethernet cable plugged in, and start the BM Video Desktop program.
6) It should then install and update the drivers for the Intensity Pro automatically.
7) Shut down your system.
8) Start up your system, and start Edius X.
9) Go to "Settings/System Settings/Hardware/Preview Device"
10 "Intensity Pro" should appear now as a selection. Check the box, and you're finished!
Hope this helps someone.
Regards,
Jon
