AMD Ryzen 9 3900X
    What 4K files do you have on those tracks ?
    Ron Evans
      Some demo-clips from Sony.
      I attached the clip properties.
      Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
        If you can run 4 tracks of those files that is very good and much better than my Threadripper with EDIUS.
        Ron Evans
          I'm building a 3900X system for a friend primarily for stills work with RAW files, however I will install an Edius test bed on it as well as Resolve to see how it fares with both Sony 4K mpeg and Black Magic Raw and Prores video files.
          It is up and running today with a lowly GTX1660 and 32gb ram - I'll post here with some results when I get around to testing with software.
          Paul :-)
            Id be interested in the results Paul, thanks.
            Tony
            • #21
              I do a lot of RAW processing with Capture One. Works very fast on this configuration.
              I'm still wondering how the best settings can be calculated … based on RAM, video-RAM, other parameters, …? I'm sure someone at Edius could explain this.
              • #22
                I did more tests with the same clips and I set the buffer to 8 GB.
                Here are the maximum number of 4K tracks playing smoothly (all with audio and all but one with layouter) :
                (1) With the clips on a standard HD: 4 tracks (the HD is the limiting factor - no surprise)
                (2) With the clips on the SSD M.2: 8 tracks (the CPU is at 100%, the GPU only 20%, the SSD 7%)
                Hope this helps others to build systems ...
                • #23
                  Buffers are not really a finite setting that has to be calculated. They are simply a reserved portion of RAM that is used to store decoded video frames before they are displayed.
                  If you are working with a good mezzanine codec like HQ/X, ProRes or DNxHD/HR, you may be able to get away with smaller buffer settings because the system can decoder the video fast. A more complicated codec may require larger buffers so that there are more frames available in ram, particularly when playing through transitions and effects because the frames can't be decoded fast. Sometimes you may even need to do buffer pre-fill before playback
                  The rule of thumb is, if your buffers don't get emptied while playing through a timeline, you are probably ok with the setting you have. If they get emptied and you start experiencing stutters and stops in playback through effects and transitions but not when a single video file is playing, you should try to increase the buffers enough to smooth that playback through more complicated areas. If you can't play a piece of video that has no effects on it without the buffers emptying, you either need a less complicated mezzanine style codec, a newer/faster computer, or use a proxy workflow.
                  Edius WG 9.55.7303, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
                  • #24
                    Thank you. That helps!
                    • #25
                      Overall it looks good, it's a good match for this money. But I still believe that you might need to pay more attention to the gpu. I am not an expert in this field, but I had some issues with it, and this is the recommendation that I give to literally everyone that I know. In case you don't know how to do this, just ask google. Write " how to overclock gpu " and you will find plenty of websites with instructions. Hope that your new acquisition will last long and that you won't have any other problems with it! Also, in case you need an IT office recommendation, I can help with that as well.
                      • #26
                        o-overclock-gpu/"]how to overclock gpu[/URL] " and you will find plenty of websites with instructions. H there this software you can tell it what you using it for and overclock it than test make sure it all good.
                        AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
                        SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
                        850 power suply
                        32GB (8GBx2) DDR4/3000MHz
                        ASUS TUF X470-Plus Gaming AM4 ATX
                        EVGA GEFORCE RTX 2080 SUPER GPU
                        Windows 10 Pro
                        HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM
