AMD Ryzen 9 3900X
  • AMD Ryzen 9 3900X
    just got amd 3900x build by CP and at first it keep crashing when rendering h264 but i found out in the bios asus has easy system tuning it was on normal i put it to optimal and no more crash and reboot. over all i am happy with amd 3900x and no quick sync but if i need long rendering i will use other monitor. today i tried to change the 1660 gtx to quadro 2000 and bit slower so going to look at gaming gpu they are cheaper and more power full.
    spec
    *BASE_PRICE: [+1315]
    CABLE: None
    CAS: Thermaltake View 27 black Mid-Tower Gaming Case w/ Gull-Wing Window Skylight View + 4x RED Riing Fans
    CASUPGRADE: None
    CC: None
    CD: None
    COOLANT: None
    CPU: AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor [+184]
    CS_FAN: Default case fans
    ENGRAVING: None
    EVGA_POWER: None
    FA_HDD: None
    FAN: CyberPowerPC MasterLiquid Lite 120mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate
    FREEBIE_SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD - Seq R/W: Up to 1500/1000 MB/s, Rnd R/W up to 90/220k
    HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD [+93] (Single Drive)
    HDD2: None
    HEADSET: None
    IUSB: Built-in USB 2.0 Ports
    KEYBOARD: CyberPowerPC Multimedia USB Gaming Keyboard
    MEMORY: 16GB (8GBx2) DDR4/3000MHz Dual Channel Memory (ADATA XPG Z1)
    MICROPHONE: None
    MONITOR: None
    MOPAD: None
    MOTHERBOARD: ASUS TUF X470-Plus Gaming AM4 ATX w/ RGB, USB 3.1, Realtek LAN, 2 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
    MOUSE: CyberPowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
    NETWORK: Onboard Gigabit LAN Network
    OS: Windows 10 Pro (64-bit Edition) [+31]
    OVERCLOCK: Pro OC (Performance Overclock 10% or more) [+19]
    POWERSUPPLY: 600 Watts - Standard 600Watts 80 Plus Gold high-efficient Power Supply
    PRO_WIRING: None
    PROJECTOR: None
    RUSH: RUSH!!! READY TO SHIP IN 3 BUSINESS DAYS.
    SERVICE: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
    SLI_BRIDGE: None
    SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
    SPEAKERS: None
    USBX: None
    VIDEO: GeForce(R) GTX 1660 6GB GDDR5 (Turing) [VR Ready] (Single Card)
    WARRANTY: PREMIUM WARRANTY: Standard 1 Year Parts WARRANTY + ONE (1) YEAR SHIPPING [+19]
    WNC: None
    WTV: None
    _PRICE: (+1661)
    SUBTOTAL $1,661.00
    850 power suply
    32GB (8GBx2) DDR4/3000MHz
    EVGA GEFORCE RTX 2080 SUPER GPU
    Windows 10 Pro
    looking for good gpu
    any recommendation for 300 to 450 price range
    850 power suply
    Windows 10 Pro
      Have a look at the RTX 2060 Super or even a second hand GTX 1070/80.
      As for your CPU. AMD CPUs are excellent and tend to be better value and more powerful than similarly priced Intels. Although depending on the type of camera footage you use, Edius is much better suited to Intel.
      Checkout my Edius video at www.Edius.co.uk
        i like the RTX 2060 Super gtx is no longer available except use one i will look into rtx2060 that looking good spec
        850 power suply
        Windows 10 Pro
          I am doing a similar build with a 3600 and Asus Prime x470 Pro, I looked at the Asus X470 TUF, but bought the Prime seemed to have better Spec and funny enough cheaper , I am still toying with getting AMD RX5700 8gig or a good 2nd hand 1070 8gig card and rather spend on SSD M.2 drives and 2x 16gig of 3200mhz ending up with 32gig at the end, Your review cleared up some things for me .On a side note it seems Asus is currently the only company that has PCIe Gen 4 active on there X470 and B450 for the Ryzen 5 and 7s
            yes go build one i like it so far pretty stabile on occasion it crash but not much maybe i am using slow portable drive. but i can overclock it easy with out going to bios.
            850 power suply
            Windows 10 Pro
              may I ask what manufacture and model ram you use-sing 3000mhz may not be running correctly and improtant to check in Bios , one thing from all my research the sweet spot is 3600mhz ram and 32gig is perfect.
                yes it came wit adata 8 gig x 2 i bought 2 more making 32 gig, than i added another m.2 ssd evo samsung for edting.
                850 power suply
                Windows 10 Pro
                  Hello, just wanted to see how the ryzen 3900X has been working for you for real time playback from edius. What files have you been working with? I edit weddings so I'll be using multicam for parts of the video from three cams ultimately in 4k but 1080p for now. No racing effects/transitions, just some basic color correction. Using Panasonic g85 so 4k isn't maxed out. Wanting to know if the 3900x will handle this in real-time with stuttering. Thanks.
                    Read this thread. It should answer all.
                    https://forum.grassvalley.com/forum/...ad.php?t=44256
                      Thank you Jerry for the link to that thread, but I'm still a little confused. Are you saying that the test results for the threadripper 3960 would compare to the ryzen 3900x?
                        The point of reading that thread was to give you the capabilities of the 3960x. Any chip below that would more than likely not be able to achieve the same performance. From that point, you can make an educated guess as to what the 3900x
                        will be able to achieve.
                          The 3900 should perform a little better than my Threadripper 1920 for current version of EDIUS. Similar 12 cores but with newer technology resulting in higher clock speed. Compared to my older 4790K PC the Threadripper is just a little faster indicating that QS makes a big difference to performance for EDIUS at the moment. For UHD not so great. It sometimes struggles even with one track full with layouter and PCC. It will just about run 1/2 resolution multicam with 2 tracks ProRes ( recorded on Ninja V's UHD 60P ProRes LT) from my GH5's and one HD track from the AX100 in a HD project. With h264 UHD 60P from the GH5's it will not run in multicam in the same setup even at 1/4 preview which is not usable to me. EDIUS is currently optimized for Intel CPU with QS and a reasonable GPU for filters and plugin's. Encode speeds are faster than realtime on my system so the issue seems to be decode for preview while editing or scrubbing. I hope ( and really expect ) EDIUS 10 will address these issues as it will become increasingly difficult to edit 4K, 6K or 8K without GPU assistance other than QS from Intel.
                          Ron Evans
                            Thank you Jerry and Ron for your responses - it helps a lot. I don't want to rely on an educated guess cause I don't have enough experience with 4K editing to make a jump to an unfamiliar CPU. I tried AMD years ago with horrible results. I may stick with the 9900K with QS as the Panasonic G85 will only shoot in the H.264 codecs.
                              What would be the best settings of "Playback buffer size" and "Buffered Frames before Playback" for my system? (see the description in my signature)
                              I've set these parameters to "2GB" and "15 frames" and playback of 4 4K tracks with layouter and some color correction filters is smooth. Just wondering if this is optimal …
                              Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
