Good idea Jerry, but I am very busy with edit work so may be up to 2 weeks time before I finish and test the new system and report back.
Do I need a graphics card for Edius 6.5 with Asus Z87-A MB and Hasswell CPU
If you have a problem with Windows activation after fitting a new card it is still easily solvable using the Microsoft automatic activation phone line. It has happened to me several times, that a working Windows has become deactivated because I changed something major, and a phone call sorted it out quite easily.
I have been using Haswells for some time but always have a dedicated card. I have occasionally just run using the on board graphics and EDIUS seems to work fine, but I want the dedicated card because I use Vistitle, as well ad DaVinci, After Effects, Premiere and other programs that really use the card.
In EDIUS without plug-ins the only GPU driven effects are the 3D GPU transitions. Everything else is CPU.EDIUS silver certified trainer.
Thanks David and Brandon, your comments are very helpful. Will give it a try with just the iGPU and add a card later if needed for my work. I would not expect adding a GPU card should cause re-activation problems but if it does I will use MS phone contact as suggested.Last edited by Peterjames; 10-15-2013, 04:16 PM.i9-7900X OC, Asus TUF X299 Mk2 MB, 32GB Mem, 250GB Samsung 960 Evo M,2 NVMe for OS, HDDs for work files, GTX1080Ti 11GB, Win10 Pro 1809, Edius 8.5 WG, Sony FS7 main camera
