Building a new Haswell i7 edit PC for Edius 6.55 and would like advice re install of windows 7 SP1 64bit oem OS. I recall reading on the forum about installing to HDD then image to SSD may be best. I am thinking of disconnecting all other video/data HDD drives and the OS SSD , then connect a spare HDD and install Win7 and updates to this (inc. Anton’s recommended user settings). Make an image of this then replace the HDD with the SSD and copy the OS image to the SSD and re connect other drives, then activate windows if all working ok. Then make further image as backup.
Is the above procedure correct or do you have any advice?
Is it advisable to defrag the OS HDD prior to making the image for transfer?
Should I install Edius plus NX and other software to the Win7 HDD before making the OS image to transfer to the SSD or wait till after the OS SSD is active with only Win7 installed?
I will be making several images at each stage of the install using Acronis True image 2012 or the Win7 imager.
Your thoughts and advice would be appreciated.
Many thanks
Peter
Many thanks
Peter
