No output in 4:3 with hdspark
  • No output in 4:3 with hdspark
    this is it: another machine with W7 Edius 6.08 and HDSpark was operated be a guy who doesn't work here with us anymore... almost 2 years and now we found this: NO OUTPUT IN A SD 4:3 PROJECT WITH HDSPARK... full HD and SD 16:9 projects works with the spar but not this... we even changed the monitor to see if that was the problem but nada... no image...
    does the HDSpark can output an Edius SD 4:3 project?
    please excuse my latin english... does HDMI can output 4:3?
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
    I just switched to PAL 4:3 project - output from Spark is good - maybe your monitor doesn't support 4:3??
    Paul :-)
      Run the EDID tool to find out what resolutions are supported by your monitor.
      My monitor has 4x3 in PAL but not in NTSC. But, it supports 640x480 in NTSC...which is worthless.
        Thanks for your info compa├▒eros...
        EDID? i found it but, how do i do the test?
        Paranova Films
        Cali - Colombia
          run the Edid .exe and a small icon will appear in your tool bar - open it up and it will list available formats
          Paul :-)
            This is a very common problem we get with lots of monitors. It is not the spark it is the monitor. We have the same issues with other devices and programs like Black Magic and Matrox and the same screens.
              Bingo
              Muchas gracias! that is (was) the monitor doesn't support 4:3 in HDMI mode :)
              Paranova Films
              Cali - Colombia
                Paul :-)
                Where do I find the Edid.exe file? It doesn't appear to be on my system according to Windows 7 Search...
                Computers should make our lives simpler, not more complicated...
                EDIUS6.08, Win 7 Pro SP1, 16GB RAM, 120GB Intel 520 SSD (Windows & Apps),
                ~4TB HDD total (5 drives, no RAID),
                Internal LITEON iHBS212 Bluray Combo Burner
                Intel i7-2700k Processor, NVIDIA 550GTX/TI, Dual Dell 24" Monitors, Kogan 32" LED TV,
                Sony HDR-XR520V Camcorder (HDD), Panasonic NV-MX300 3CCD Camcorder (Tape-defunct), GoPro HD Hero3 Black Edition
                  open EDIUS and go to tools menu
                    Walter
                    It is in the Program Files<>Grass Valley<>Edius 6 directory BUT only if you have a GV Output card like a SPARK etc
                    Depending on the version it has many names "HSX-E1 Monitor, EDIDMonitor.exe, details in the SPARK or output card Handbook
                    With 6.5 or later it is in the "Tools" menu
                    Barry
                      My monitor does not support 4x3 in NTSC but it does in PAL. My monitor does however support SD 16x9 so I use that for assembly purposes only.
