HDSpark with Edius 5.12 on W7
  • HDSpark with Edius 5.12 on W7
    I've had a big problem with the HDSpark card. But not anymore.
    I recently bought the EDIUS 5.12 with HDSpark card set.
    I work with a 3.0 Ghz Intel DualCore Proc with a lot of HD space and EDIUS 5.12 combined with the HDSpark card and my OS is Windows7.
    All is well installed. Edius recoqnizes the card and the HDMI port works fine with the TVmonitor set.
    The only thing what I had to do was learning to work with this combination.
    Now I've read a lot of messages on the different Fora and started to work with it and got more nad more experienced. Now I can say to be very glad having bought this combination!
    It works very fine under Windows7 Ultimate. Absolutely no problems.
    I was too soon with my message.
    With kindly regards to everyone.
    Gerard
    Last edited by Gerard; 02-14-2010, 07:17 AM. Reason: My message was NOT correct. It was MY mistake.
    Edius 5.5.12 with HDSpark card
    Acer Aspire Intel Core i7 8 Cores 2,95 Mhz 8 Mb RAM Memory
    Windows7 home 64 bits
    1x 60 Gb SSDdisk for the O.S.
    4x 1Tb internal Harddisks
    Canon HD Camera Legria HF200
    My perfect combination for Edius
    First of all there is no support for Windows 7.
    Second AVCHD must be converted to canopus HQ (full HD).
    There is a free converter for that is in the download area.
    Third EDIUS Neo booster can EDIT AVCHD native in real time now.
    (I think you did not do your research. )
    So my advise is batch convert with the AVCHD to HQ converter and you will be able to edit in FUll HD (not lower resolution as you wrote) without any quality loss.
    (Ik denk dat je even goede informatie moet inwinnen alvorens zo te klagen dit zijn echt gebruikers problemen. goede tip een beetje minder schreeuwen werkt altijd om goede hulp te krijgen van forum leden. :)
      And fourth the Spark card only provides external monitoring. It does nothing as far as editing power is concerned.
        Correct. I forgot to add that one.
        I think the Op will be very happy editing in HQ. We just need to help him find the right workflow.
          I think Steve hit the nail on the head. You need to do your research prior to
          purchasing anything. Also, I think he may be a little under powered with just a dual
          core 3.0(unless it is the extreme edition). Even with Neo and Booster, he would not reap
          the full benefits of Booster due to the Proc model and speed. He will be able to edit
          1440x1080 files pretty easily, that said, if working in 1920x1080 he will be reduced to
          1 or two streams of HQ-depending on whether he has a fast raid or just drive space.
          More than likely he is using an older video card that does not have a hefty GPU for
          the effects.
            Originally posted by Gerard View Post
            [B]I'm working with material solution of 1920x1080 from Canon .mts .............
            It seems that the HDSparcard doesn't work after all.
            HD Spark/EDIUS 5.12 works perfect on my Windows 7 System.
            The probleme is your footage.....
            Eric
            English is not my native language
            ___________________________________
            System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
            System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
              Yep working fine here too, never had a problem with spark on Windows 7 64bit.
                Same as Steve, no probs
                  What about Windows XP 64bit
                    No problems here either. HDSpark card with Win 7 X64
                    Tom Koveleskie - Director/Producer/Editor
                    Quarter Town Films - Independent Feature and Documentary Films.
                    Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
                      Pentium 4, Windows 7 and AVCHD. Wow, you really needed to seek advice pre-purchase.
                      AMD Ryzen 9 5950X, AMD Radeon 6800XT, 64GB RAM, EDIUS X WG.
                        What about HDSpark card with Windows XP 64bit? Anyone has experience with it?
                          Originally posted by Jeordie View Post
                          Windows XP 64bit?
                          I think you have a hard time finding any working driver for XP x64, you really want to go there ?
                          As far as I know none of the GV software is endorsed for XP x64.
                            I'm so sorry having said what I said about EDIUS 5.12
                            Hi everyone,
                            I really am sorry having said to be sorry having bought EDIUS5.12 with the HDSpark card! Because I have had a totally other awaiting from this combination as it was and that was my mistake.
                            But after I have had read a lot of satisfied reactions on more then one Forumboard, I said to myself: "Gerard YOU have to be wrong somewhere because it is impossible that a lot of users are totally satisfied and you are not."
                            So I did what other users did before me. Not complaning and working with the combination and get the experience of working with a fantastic combination!
                            So I really apollogize for what I have said before and I'm turned over to be (and to stay) a really beliefer in the Greenvally EDIUS 5.12 program suite.
                            I hope everyone who I heart with my sayings will accept my apollogie.
                            With kindly regards.
                            Gerard
                              Hi! What about HDSpark card with Win XP 64Bit.
