need advice on GPU
  • need advice on GPU
    hi there,
    I'm planning on working with Edius 5.12. For this I want to upgrade my graphics card. I am looking for a single slot card with 1Gig of (preferably DDR3) memory.
    It would be great if the card is both quiet and with relatively low power consumption. I don't play games, i just want great effects performance in Edius.
    Any suggestions?
    thanks a lot
    Check put NVidia cards from say GTX260 up to the GTX295, you can pick them up pretty cheap now, check out EBay.... or wait a little while for the new 300 series NVidia cards, due soon.
      I have a slightly different problem. 99% of the graphic cards these days all occupy the physical space required by 2 slots. I can't release the spare slot because my PC slots are all fully occupied. Any good graphic cards you know that only occupy one physical slot?
      *** Addition ***
      Just checked up Nvidia website - the new 310 card will fit this bill (if it really occupies only 1 slot width). Hoping ...
      tingsern
      Senior Member
        *** Addition ***
        That is precisely my problem too. i would like a graphics card for just one slot. It seems that ATI has some but I don't know how they perform with Edius 5.12
        Apparently most Edius users have NVidea cards, is that because of compatibility issues with ATI?
          As far as I know there are no Edius compatibility problems with ATI cards, as many of us here are system builders we have come around issues for me with the drivers, hardware I have no real issues so far.
          I think similar goes for the CPU, once one is bitten before you tend to be twice shy :)
          No ill feelings towards AMD but not for me .......
          P.s. I am not brand concious (enough) to stick with A while B is better performing at the time of purchase, same goes for software.
          I have no problems to switch camp for both, at the time of upgrade or new build, cost of course is always a small factor :)
            My ATI 4850 card works great. Edius will work just fine with either ATI or NVidea. I don't think anyone has ever reported compatibility issues with ATI cards.
            Tom Koveleskie - Director/Producer/Editor
            Quarter Town Films - Independent Feature and Documentary Films.
            Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
