HD Storm setting in Edius
  • HD Storm setting in Edius
    Hey dudes,
    I found a check box in the hardware settings for HD STORM, just wondering what it does (a little more info anywayz). Check box is under HDMI settings and says:
    Disable FIR filter at RGB/YUV444 to YUV422 conversion
    FIR Filter? What would this achieve? Compatibility with different monitors maybe?
    Yeah it would be good to know what they are for.
      A couple of good Google results:
      OpenStax offers free college textbooks for all types of students, making education accessible & affordable for everyone. Browse our list of available subjects!
      Finite impulse response (FIR) filters are the most popular type of filters implemented in software. This introduction will help you understand them both on a
      Essentially it's the signal-processing filter.
        So the option is to disable a filter that blocks out unnecessary signals when converting from RGB to YUV422 color space or YUV444 to YUV422 color space....Cool.
        So that would be irrelevant in the case of HDV editing then?
          As I read the description, seems it's only for the input, as the HDMI input might be RGB444 or YUV444. Upon capture, it goes to YUV422, so beyond that, output ends up YUV422, so it's irrelevant on output as far as I can tell.
          As the filter alters the incoming signal, there may be certain instances when you don't want it enabled, so the option exists to disable it.
            Sweet, love to know this stuff. Thanks :)
