After effects and Edius
  • After effects and Edius
    If I make a comp. in After effects in 720p how do I export it to bring it into Edius?
    Randy
    Canopus HQ Online, Upper Fields First, 29.97fps
      Actually use No Fields (Since 720 is always progressive), I was looking at the 1080i settings for EDIUS projects.
        Two quick questions on this same subject
        If I have Edius and After Effects installed on the same machine, will AE have access to all of the Canopus codecs (read and write or should I say decode from and encode to)?
        How do I export a composition from After Effects with alpha channel, to be used as lower third for example in Edius?
        Thanks,
        Ervin @ www.AtlantaLegalVideo.com
        Edius Pro 8 with TMPGEnc plugins | Windows 10 Pro on Samsung 970 Evo M.2 | Asus Z97 | Intel i7-4970K @ 4 GHz | 32 GB RAM | 4 x 1080 monitors on NVIDIA GTX 1660 6GB DDR5 | 1 x 1080 monitor on Intel HD 4600 | Storage: 3 x 4 TB drives + 1 x 16 TB archive; all drives network mirrored & automatically synched
          1- yes it will
          2 i suggest quicktime (animation codec) millions of colors+ (note the "+") and be sure that your AE comp does have transparency
          2a- when importing to EDIUS you may select the "Progressive" option under "field order" to your .mov... it is the best choice to me
          and please excuse my latin english
          Paranova Films
          Cali - Colombia
          http://www.paranovafilms.com/
            Is there no Canopus codec option for the export with alpha? HQ is so much easier on my PC compared to QT...
            I know I can transcode the QT file with alpha to CanHQ after import and it will retain the alpha, can I do this directly in AE to skip a step?
            P.S. Your English is better than my Spanish, so don't worry, there is nothing you should be ashamed of! Oh and by the way, I love Colombian coffee!
              You can export canopus HQ+alpha out after effects.
                As Steve said, HQ is the better option with Edius.
                  we (editors here) use QT just to share with anothers PC that may have no EDIUS or canopus codecs, but, i agree that Canopus HQ is better for Edius...
                  Thank´s for that my friend!
                  SALUD!
                  Paranova Films
                  Cali - Colombia
