Shortcut to specific speed
  • Shortcut to specific speed
    Greetings,
    How can I set up a shortcut to a specific speed? I already have one to the speed window, but I want to be able to have a single keystroke for 50%, 60%, 65%, 70%. ( that would be 4 different keys).
    In my opinion => not possible.
    Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
      Bart is right, it's not possible.
      There is an easy way that, though.
      Select clip, ALT+E then use the numpad to enter 33 for example, then numpad enter. A few keystrokes, but really fast if you get used to it.
        Originally posted by LegalEyes View Post
        Greetings,
        As everyone has said it is not possible at this time. Dave's way is about as quick as it gets :)
          Wrong, if you remap it from Alt+E to S (for speed), it is one keyboard quicker. heh heh.(-:
            Ok... You got me!! it could be a tad bit quicker! :)
