Marking Clips in the bin?
  • Marking Clips in the bin?
    Hi
    Is there a way to mark a clip in the bin somehow to show that is is used f.ex.?
    I have a lot of clips that look a like on the first frame and would like to give them some kind of mark that shows that is is used.
    /Ulf
    Best regards * Ulf * Denmark
    mail to me
    I think you can colour code them, Not sure though...
      why not change the thumbnail of the clip to indicate what it is used for
      push mouse scroll wheel down and then move mouse right or left
        Wow! Thanks Anton - that's a real time saver for clips that have a corrupt start :)
        Hedley Wright
        Partner - Brett Vale Studios
          Originally posted by UlfLaursen View Post
          Hi
          /Ulf
          Right click the bin menu bar and it provides a long list of clip information which you can choose to show. This includes options to show both bin reference count and timeline reference count (which I always use) and a clip marker reminder.
          DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
            If you want to see if a clip in the bin is used in the timeline, change the view of the bin to "clip width small" or "clip width large". A used clip has a green dot in the left upper corner.
            Edius Workgroup 8.53
              Thanks a lot guys - got something to work on now :-)
              /Ulf
              mail to me
