I accidently deleted a project folder and now I can't erase it from the startup screen... Any ideas on how to delete projects so they won't appear there? Thanks!
How to delete projects on Edius 5?
No (official) way for this, it is (imho) for 50% a feature, and for the other 50% deficit
feature = have you projects on removable disks, they shows ditto offline if the disk is not aviable for the OS
but with change the (fo this offline-project) correct disk, .......... yupp it shows online, ready to start.....
open your last 5 online- project's, >> and the "offline-Project" will go out of your starscreen (settings " display the last 5 projects")
(unofficial way = editing files .... your risk ... and needs more time as opening the last 5 projects, or i.e. make 5 dummy projects)
look at:
friendly greetings from the "inhouse-librarian" ....... old (but not morbid) HansEdius 5,51 / Edius 6.08 / Edius 6.54(b) / Neo 3.0 / Neo 3.5
