I have an older system which I would like to upgrade so I can use the HD Spark. I would like a recommendation for a motherboard and graphics card which will work well with this card.
Spark System
I am using the system listed in my sig with HDSpark. Not sure what you are editing (or how you plan on ingesting video), but this combination is one that should work for you without any surprises.
If you are upgrading an older machine you will need the motherboard, CPU, RAM and graphics card. This assumes the case, power supply, hard drives and CD/DVD burner (and an OS) can be used in the new system. Edius 5.01 is required for the Spark.bejay
Primary - Gigabyte 890FXA-UD7 / AMD Phenom II X6 1100T / 8 GB RAM / ASUS Radeon HD 6850 / HDSpark / W7Pro64 / Edius 551 / ProCoder 2
Secondary - Asus P5Q DX / Intel Q6600 / 8 GB RAM / NVidia 8600GT / W7Pro64 / Edius 551 / ProCoder 2
