Now I have stable hardware I can't quite figure this problem out.
I've searched the forum, but no joy.
I've skim read the manual but haven't found anything yet.
I can capture a file via firewire on the nx bay, whilst it's capturing I can hear the audio both from the cam and the pc speakers.
When I drop the file on the timeline, there is no audio waveform to see, and no audio to hear.
Playing the video file in WMP results in audio, so it is there, I just can't figure out what I need to change in Edius.
I don't have any of my test projects from yesterday when I could hear the audio, as I deleted them all :(
I also cannot add a music file to the audio tracks.
I think somehwre the whole audio is turned off or set to the wrong setting, but I just can't find it.
I've been through the project settings
NHX-E2 SD PAL
DV 50i
Video 720x576
25
1.0667
bottom field first
Audio 48khz
16 bit
channel 2
rendering dv-avi
tc 00000
non drop frame
audio reference level -20db
Channel map is set to default settings.
I've searched the forum, but could only find a keyboard shortcut for waveform shoing, which just turns on or off the view of the audio track.
I've looked through hardware settings, but can't find anything particualrly audio related, but have set everything to default, which they were anyway, apart from video overlay.
I'm going to start a totally new project and see if that helps.
It hasn't helped, still no good.
I can double click either the video file or the audio file and watch/listen to them in the preview window!!
I've tried using disc capture and captured one track from a music cd adn it again plays in the preview window when d/clicked but I still get a cross when trying to add it to an audio track.
It's as if all the audio is locked somehow.... But the padlocks aren't pressed, mute is not pressed.....
Graham
NHX-E2 SD PAL
DV 50i
Video 720x576
25
1.0667
bottom field first
Audio 48khz
16 bit
channel 2
rendering dv-avi
tc 00000
non drop frame
Graham
