Will this work with Edius 5?
  • Will this work with Edius 5?
    Looking to build a computer made by Velocity Micro. I configured this system and was wondering if anyone saw conflicts with it and Edius 5.
    Genuine Microsoft® Windows® Vista Home Premium 64-bit, with Service Pack 1 installed
    550 Watt Velocity Micro® Power Supply with Dual Blue Lighted Fans
    Motherboard Genuine Intel® P35 ATX Motherboard with DDR2, PCI Express, 1333MHz FSB, RAID DP35DP
    Processor Intel® Core™ 2 Quad processor Q9550, quad 2.83GHz cores, 12MB L2 Cache
    CPU Cooling Arctic Cooling® Freezer 7 Pro Heatsink, Ultra Quiet Fan, Copper Heat Pipes
    DDR2 Memory 8192MB Corsair XMS2 DDR2-800 Low Latency CL5 Extreme Memory with Heat Spreader (4x2048)
    PCX Video 512MB NVIDIA® GeForce™ 9800 GT Velocity Micro Performance Edition
    Audio Creative Labs SoundBlaster® X-Fi™ XtremeAudio
    Hard Drive 1 500GB Hitachi 7200rpm 16MB Cache SATA 300 w/NCQ
    Hard Drive 2 2 x 1TB Hitachi 7200rpm 16MB Cache SATA 300 w/NCQ - RAID 0 Stripe (2TB Total)
    Optical Drive 1 4x Lite-On Blu-ray Burner
    Optical Drive 2 16x DVD/48x CD-RW Lite On® Combo Drive, Black Bezel
    Media Reader Integrated 52-in-1 Internal Media Card Reader
    Network Adapter Integrated 10/100/1000MBps Gigabit Ethernet Network Adapter
    802.11g PCI WiFi Adapter
    FireWire 2 Integrated IEEE 1394 FireWire Ports, 1 front & 1 rear
    this is an old motherboard but it is stable and works very well with NX and HDStorm boards...
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      Is the PSU at 550W getting a bit marginal??
      nev
      Edius 8.5, Asus P9X79-PRO, Intel i7-3820 3.6Ghz, Samsung 256Gb SSD, 16G RAM, Asus GTX560, 750w XFX psu, Win 10 64b home prem.,ASUS BW-12B1ST black writer, Rode USB Podcaster mic
        nev
        Yah, but the lights make it cool!
          A bigger PSU for sure.
            Thanks for the help, I appreciate it.
            Here are some of my options with a asterisk by my current top choice.
            Power supply
            500 watt
            850 watt Nvidia SLI certified
            *1200 watt Nvidia SLI certified
            Processor
            Is the 3.0 going to make that much difference? I thought I would go with the 2.83 unless the 3.0 would give me a big advantage because $1145 seems like a lot to pay.
            Intel Core 2 Extreme QX9650, quad 3.OGHz cores, 12MB L2 Cache, 1333MHz FSB (45nml) +$1145
            *Intel Core 2 Quad processor Q9550, quad 2.83GHz cores, 12MB L2 Cache
            Intel Core 2 Quad processor Q9400, quad 2.66GHz cores, 6MB L2 Cache
            Intel Core 2 Quad processor Q9300, quad 2.5GHz cores, 6MB L2 Cache
            Videocard
            *1 GB NVIDIA GeForce GTX 280
            512 MB Visiontek Radeon HD 4870 GDDR5
            896 MB NVIDIA GeForce GTX 260
            512 MB NVIDIA GeForce 9800 GTX+ Velocity Micro Performance Edition, PCI-Express
            512MB Visiontek Radeon HD 4850 GDDR3
            512MB Visiontek Radeon HD 4850 GDDR 3
            Operating System
            *Geniune Microsoft Windows Vista Ultimate 64-bit, with Service Pack 1 installed
            Geniune Microsoft Windows Vista Ultimate 32-bit, with Service Pack 1 installed
            Geniune Microsoft Windows Vista Business 32-bit, with Service Pack 1 installed
            XP Professional downgrade option
            Geniune Microsoft Windows Vista Home Premium 64-bit, with Service Pack 1 installed
              Anyone see any issues with the listed components?
                I don't think that you will have any issues... everything seems ok...
                Ctrl+Alt+Delete
