I would like to get the best quaility finished DVD possible. I have read and read here and most I read was regarding HD to SD workflows. I have googled and searched here but found nothing definitive. A direction where to look or a workflow list would be great, Thank you
I have a SD pal highend consumer camcorder DV tapes to capture.
I have Edius 5.01 with dongle, meaning not trial.
I have on another system Edius 4.61 and DvStorm 2
I have Tmpgne(sp) 4 encoding software
I have made a short timeline of a little over one minute and have gone through every possibility/combination of steps I can think of, using what I have, to burn finished DVD's. The quality ranges from not so good to OK.
I have used a stand alone DVD authoring program and the one included with E5.
After I made my short test timeline I went straight to "print to file" and also"pint to DVD". I tried several of the formats to save the timeline first to AVi's and then convert to Mpeg 2 and ac3. As an aside, I am very disapointed that there is no elementary mpeg 2 streams possible with the exporter.
My question is what would be my best selections for the best quailty DVD with what I have or what I should buy for software/hardware that I don't have.
